Ford Van Sliding Door Alignment
You can adjust the rear hinge/slider where it mounts inside the door.
Remove the interior panel and you will see a large bracket with several bolts.
The MG slider hinge extension PDF has pretty good instructions for symptom/solution troubleshooting of slider hinges. Not sure if he still has it posted anywhere.
Bobbyjr
