Looks like you're in Sugarhouse, so you surely have some rust.
Wire wheel the frame and paint with POR-15.
Close, actually in Bountiful, and definately there is some rust
Looks like I have some other things to fix first
thats standard operating procedure right there.
At one point, my friend and I were so well versed in swapping diffs that we could do the whole process from drain oil to fill oil in about 15 minutes (using air tools).
Fronts are slightly worse, 15 minutes was a rear diff with steel wheels (so you could pop the shafts out without taking wheels off)
On an older truck the fronts are quick if you pull the 7 bolts holding the swivels on each side and slide each knuckle out a few inches complete, but thats not possible on a D2. Happy trails.
