Fridge Help
heeltoe989
Hi guys!
I know some of you are running overland fridges and I just got mine a few weeks back (ARB Fridge Freezer). I'm wondering if there are any sort of calculation I can do to see how long the fridge will run on my aux battery with the truck off? I have a battery gauge but it would be nice to know a running time.
Any help would be much appreciated!
Richard
Martyn
Hi guys!
Richard
Here is the basic info for you from http://www.adventuretrailers.com/12volt_solar.html:
Tips for Evaluating 12 Volt Power Requirements
In the same way that we plan our trips revolving around our MPG and miles per tank, we need to do the same for calculating our auxiliary electrical needs. It’s really quite simple: The key is Ohms law. It is a basic equation that can be read a few different ways depending upon what number you need to crunch:
Volts x Amps = Watts
Watts ÷ Amps = Volts
Watts ÷ Volts = Amps
Let’s say you want to know how many Amps an ARB 13Watt, 12V fluorescent light is going to consume per hour. Your answer is 13 Watts ÷ 12 Volts = 1.08 Amps per hour of usage.
Understanding Deep Cycle Battery Basics
The Group 31 Valve Regulated AGM Batteries that we favor in our trailers and vehicle conversions are very stout. A general rule of thumb for calculating available power from these 105 Amp hour batteries is that no more than a 50% discharge (52.5 Amps) will give you the longest battery life and the most cycles. A cycle is each full recharging occurrence. Unfortunately, often we need to discharge beyond this 50%. A deep cycle battery is considering completely discharged when it reaches about 10.5 volts. Below 10.5 volts, most 12 volt appliances stop working. This is approximately 80% (84 Amps)
105 Amp Battery
So here’s the math again. Using our 105 Amp Battery and the ARB 13 Watt, 12V Fluorescent light as an example:
(105 Amps X .80) ÷ (13 watts ÷ 12 Volts) = 77.7 Hours of burn time.
heeltoe989
ok.
Just working this out my fridge is 12 volts x 7A = 84 watts (Confirmed with ARB USA)
I have 2 red top 34R as Aux's which is 100 amp/h.
(100 x .80=80) divide (84/12=7)
80 / 7 = 11.42 hours of run time?
This would be full run time too at 7 amps all the time. Now the fridge has different settings so I think there is a lot of variables to this equation. This would constant running as the new ARB turns it self off after it reaches its proper temperature.
ARB claims a 66 hour run time on the spec below, and I would be around those temperatures. which means I would have about 132 hours of run according to ARB's sheet running 2 batteries.
Specs
http://www.arb.com.au/products/arb-freezer-fridges/300range.php
Have I got it?
Thanks for your help Martyn!
RHINO
i'm a real simple guy and this is how i got a good idea on mine,,,, i put a few things in the fridge then left it on with the truck off. i got a day and a half in 90*F temps. (the nite and half the next day)
when doing your calcs you should also remember that the taco and the fridge have low power shut offs, so your never going to drain your battery, it'll only drain to about 10.7 volts or so. so if your fully charged at what 12.2 volts how long will it go till it shuts off? plus running on and off not full tilt 7amps..... i dunno thats why i'm a simpleton.
Corey
OverCamping Specialist
The longest I ran my ARB fridge was last year sometime during a long weekend and I did not drive anywhere.
Ran the fridge non stop for around four days, and it started right up when it was time to go to work.
Temps were mild, not super hot outside.
This was on the stock FJ Cruiser battery.
flipstick
