Hello,
I'm in the process of replacing my front drivers side driveshaft. The shaft will not release from the differential. I started out pulling gently, then progressively harder and harder. I removed the inner boot and outer portion of the shaft to get it out of the way. I'm now left with just the inner part now that goes into the diff (see photos). I tried using a hammer puller with a vicegrip bit onto the lip and no dice, it won't even come out with that kind of force (the vicegrips eventually pull off). I'm planning on drilling a hole through the piece that remains and put a shaft through it so I can hit it again with the hammer puller but with a straighter pull. If this thing won't come out, is it possible to remove the keeper clip from the inside end of it if I remove the front differential cover? With the diff cover removed can you even see the inside end of driveshaft?
