FS: 2017 Nissan Frontier CCLB w/ Hiatus Camper (hardwall)
lkadjflakjsf
The Truck
2017 Nissan Frontier SV 4x4 (crew cab / long bed) 78,500km
I purchased this truck @ 73,000km and have changed all fluids with high-quality full synthetic fluids except for the power steering.
The truck has a rebuilt title from relatively minor front-end damage. All repairs were professionally done, and certified by ICBC (Insurance Corporation of British Columbia). The truck has a 2.5-inch lift front and rear (details below) with Falken Wildpeak AT3W 265/70/16 tires. This truck was used for camping and mountain biking trips, e.g. no hardcore off-roading/rock crawling. Bike rack not included in price.
$60,000 CAD
Body
Asfir full aluminum skid plates (brand new) (https://www.asfir.com/skid-plate-set-591070b.html)
Coastal Offroad steel high clearance rear offroad bumper (https://www.coastaloffroad.com/product-page/2nd-gen-frontier-high-clearance-rear-bumper-kit/)
New SKF front hub bearings
Fumoto oil drain valve
Rear differential breather mod
LineX professional bed liner
Front Suspension
ARB Old Man Emu Nitrocharger Sport Strut - 90003
ARB MD Front Coil Spring Pair - 2607
1" Lift Top Plate Spacer
SPC adjustable and greasable upper control arms
Adjustable sway bar links
New lower control arms with greasable ball joints
Rear Suspension
Custom heavy-duty leaf pack
CJD adjustable extended shackles
Bilstein B8 5125 extended travel shocks
Extended bump stops
2.5-degree axle shims
Hiatus Camper
Hardwall popup camper (https://www.hiatuscampers.com/)
Custom fabricated to fit both Nissan Frontier AND Toyota Tacoma
Custom 80-inch sleeping bed length
MaxxAir powered fan
Side hatch access
LED dimmable interior roof lighting
My additions to the camper
Propex propane furnace (dry heat!) w/ 10lb propane cylinder and external aluminum door mount
CO/CO2/Propane 12VDC RV alarm/detector (suitable for high humidity environments)
Renogy 100ah self-heating lithium battery box with USB/Anderson connections
Renogy 30amp DCDC/MPPT on board charger with a portable 120w solar panel
1/2" plywood waterproof treated flooring with 1/2" rubber bed mat on top
Custom L-track mounts throughout the floor and bedsides
45L 12VDC fridge/freezer (Can also be run on AC with the adapter)
Front and rear dash camera/backup camera
2m x 2m ARB awning with 3 wall room - this can be mounted on the side or rear of the truck to make an extension.
Front and side ARB awning mounts
Rear-facing Rigid LED flood light
Thule roof rack crossbars
DeWalt TOUGHSYSTEM 2.0 Extra Large Tool Box with a set of winter rear tire chains, tire repair kit, and jumper cables.
I have the same truck, similar build with a Vagabond Drifter camper. Curious if you have any interior photos and how you mounted your Propex? Also, if you want to part with that separately, let me know! I’m down in Seattle.
Good luck with the sale, it’s a nice truck and camper!
lkadjflakjsf
At this time I won't be parting out, there is a small chance that I might sell the Hiatus separately and keep the truck. Frontiers are a great platform and the aftermarket support is continuing to grow. The truck and camper combination is thoughtfully designed. The camper interior is modular and everything can be removed in about 10 minutes to maximize space. I'll get some photos of the interior and the Propex installation soon.
BruLew
I'm assuming that's a 5-foot bed with the Crew Cab, right? I have the King Cab with a 6-foot bed but it's the Hiatus camper that is interesting to me.
(none)
I'm not the seller, but his truck is a 6' bed. One of the semi-rare long bed crew cab SVs.
BruLew
I kept looking at it and thinking it was longer than 5-ft. Having the full cab AND the 6-ft bed is kind of a big deal although the longer wheelbase might not be as desirable depending on what one is doing with the truck.
AggieOE
Trying to escape the city
And on the contrary, the long wheelbase sounds perfect for most long-distance general overlanding where one isn't rock crawling between camps. Small lift, long wheelbase, near OEM size tires, I bet it drives nice over long distances.
BruLew
Nothing to contradict. Like I said, the longer wheelbase might not be as desirable depending on what one is doing with the truck. You made my point.
lkadjflakjsf
Correct, it is CC with a 6-foot bed. With the high clearance rear bumper, I haven't found a water bar/cross-ditch that I haven't been able to pass through. With sliders, a locker, and 33" tires this truck would go almost anywhere if that's what you're looking for, see @thefrontieradventure on IG for a similar build. There is a chance that I will part with the camper separately. DM with an offer if interested.
Yeah I have the same set up. Can confirm not a rock crawler, turn radius isn’t great but lots of space, better for camping than the 5ft bed. Also a much smoother ride on washboard and pavement due to the longer wheel base.
Waiting for interior pics.
Does anyone know the process for importing a vehicle from Canada into USA with a "branded/rebuilt" title?
If I had cash it might not be an issue but there might be insurance issues and financing issues I would like to be prepared for. Thanks for positive input.
lkadjflakjsf
fireofficer001
