FS: ExtremeAire High Output 12 Volt Air Compressor
conquest26
For sale is a gently used ExtremeAire High Output 12 Volt Air Compressor that came out of my Jeep JK. The compressor was just tested by Extreme Outback Products in Vacaville, CA and has a clean bill of health.
New these sell for $429, I'm asking $300. Local pickup preferred but will ship (buyer to provide shipping label or pay actual shipping costs). Thanks for looking!
Here are the details from the Extreme Outback website (link here):
The ExtremeAire High Output 12 Volt Compressor is setting the standards for high capacity compressors. By utilizing a 3/4 horsepower fan cooled motor, overheating is a thing of the past. Designed to fill the largest 4WD tires or the highest-pressure RV tires, this unit can fill tires continuously with no fear of motor burnout. With a 150psi continuous duty working pressure (200 psi max), you can fill air tanks and run impact guns to dismount and mount wheels easily. For clean air in the dirtiest environments, the ExtremeAire uses a USA made metal air filter with a replaceable element. In addition, the fan shaft has a sweeper seal to keep dirt and debris out of the motor and brushes, at the same time, allowing moisture and condensation to escape. The ExtremeAire is permanently lubed with sealed bearings so it can be mounted in any position making installation much easier. Every ExtremeAire utilizes stainless steel fasteners for a long and trouble free life in the highest vibration applications. Uses for the ExtremeAire include 4WD, RV, Agricultural, Construction, Motorsports, etc. No other 12 volt compressor has the speed, continuous duty cycle, output, pressure rating, and reliability that the ExtremeAire can deliver.
Tech Specs:
- Continuous duty fan cooled motor
- 3/4 horsepower motor
- 49 amp draw @ 100 psi
- 1.5 cfm @ 100 psi
- Continuous duty up to 150 psi, Max pressure 200 psi.
- Can be mounted in any orientation
- 14" long, 6" wide, 9", tall
Photos:
nDRX2KW5aVIKmOj4sJmRWL2i4Rg7Tp3cLCI37fMmwAUt0ZUjX98mcEMomxT7nLs6xCx-a4n3IWRGiDvLMBZgbTpGDQ-nXotxdcIHbtJz3GTPy3fV3IUW_8iKL8LPpPG8hOr5qXK5LzXWSg8Mr984XWaUEvwG1wmQgfQB5CQifI-KyBqiJIYq0MUVMA9JEK58O0E1Frix94KkK2MSpBM26ToKpAPe4bbgxJnQh8h-g78XsiXqhcPSv7fj_D9ZnOmzHdOVQDEN8fgfjHGsTdB2fo7GifLniWPH3hjsMdHQgV-uReuAK-tCjVenvKX3dkrw6w45GYkIdZtysgVXgcMuDN6sCRKLv3o1srPk_qhsGrGAiBOoN8i4sx8jys7yTxW4REBhy6DA1iOt8Vm2f7dJuFbb8NwyKovXR9N7ipnYs8PfkuKBKGIp9zysJtT9gJQsvRuTT2ZOC95gtfyKccCXgYHmKJHSMZyvuOMzVwfTwyE0DQ-gxvA5oUAIb-sPEMd4IWCVZnXyq8zQpbfm-Q0kd-trYecZKODmttqafwZsgtyVEeEX6-BcZfrrEPXGpDyepaZEtkVhxLvf_mTI2ruF6Vd9ECFED2YHhoPPxAB_GvltRjdBLiLK=w2024-h1518-no
1nlL8XJtri8z0677CZWEhttAmQuJ-5q2yShEv3_qUNJZVoCPcNFybgZ_-B7K63bJ61rmHHBCEXX20O_QBa71lv2qQVgfKW3j99_hDQjkjhXMAeysbDfm5UTwgIZQHdmvl3G0hlU7NG5K7_2sJIpypVY77DsDEWy6wWw7EBDEc9485tlj9geZt6_aAs8cnbuDdO8qjMJvuVjiL_qKEl4F-YIA4QCs444tHYIpWifXzBbiZGePkQOy_Bh7cMU0Nu4CwhX3QYwF1-Om06z0aHpvkptVIvCPRwKiXRbq4opJtrF9ep4zfQRqMFawa7JRtpUK7Nzf8jsS35v7fmtb8ndKXDrzL0JidDMI8kGC71FosK-J3pKszfS0EyoziNByKntJrjSUEV3xJmcsCF-SmRbkb31yD51Gvj9ZrWyUBOiULQdLvlQzslRPdBVgFaUegvqHulykx7Uid3bR8GbL5gLFwRagf7j1IgT1lOHHCkY27OaeFr8LMDVljAZtA02_74wmPjEUPsPmsYZYur0VSiGW-iej-s4dPQkOqIhEYsrw0JYWMQ4Az6vd_cxn6k3leuyFueytqWbBXuL9QPtamDii-7NMDbq89N4X9cW6mxRpielkkOot=w2024-h1518-no
RRZrVlh-cH5hnzidl-WDGHzmSUXzqHZvtKKPuoDSyiSmrbO8PqxaYdaoOrIeOVnhbnQdFRxFcuIyA6v_5fhQZtqX58pJ0GCT2JWydRUcta9iOLT3KorzL403FZk2rmCWmIVyFGKXkHLJwsc3ttEE3UXo8kiE8PcPssg53zYyIPBOaDGsEj0_-PLC7SmS5XUJsKiof0S0zl0tElHpDZ27QOscAEFeMobcY_nArEYgjKXLYv0274QAAmYPxr8E9SI3QDnX3L5WdsZ5s1iMTfmhqJxGwPzbJE1nux_IcaX25i-b4Mtps2DVqGrhcaItABV4iP-mIyQM5jpnRC244VXNXskweiZTGTzDhnDZRIPU4gdzRHGqUvQiCTUBIVfQZY4FLWcunDQLWU9cI15T-1fbFWbcRIMedqXmHW3SkuGOxRx66ElfdJ5eLyz2jXpJVZTyb-KTV_KkUaJGw-WTTElcK54OoBAmcTFDNcX3F2iGNl62wDoJ9s_nE8jyw6AKLtgFV7TNYJVIoceOGOlR_SnULOb3U8Qv10GY32MyKFqEQiA2cEZWOvW4GhbttEkWzV8ai9r9oQC88HFVXDpyJdF-ay79_vXSZiAoXLjCCSEcXd4PMEhFsRQXeN235G59tzfSellBSzO4mzT0QRYCU2ithL88jqusGIBliFmpX4vqSw=w2024-h1518-no
VHOfzJl1wZcoomT1ccQ2NnogYlUJJeIe7-PN58T4Qri_eiWzMmQ1qYUL-S0U7TL0aZ7bqTdOmGRUDAsF67DSJ4ZyQ1bdBb4vhIluX46-8CVKlUa0iVdM465M4pRBDwQHd7pCD2p79jerPGJ-2EMVLB3Tfgkoa2RhAX7123Ni1aGEa4K8AzUtMx_O55YMeWAoB6a9X42xye4hD93J5VVM2Ufsm2v4EPKcs0AsxAT1hoIsDQusL8vjXp3XE3UUkX5_sWTxB065OCRNrrw6v7yGThsqDz_RbODAcZz3xBF5Dp9HZSyCg1zb_emcWl5yq_VYxAXzVZQAezUK829bDeUrGQKHOszn3ICOQb3EwEE7uBIsr5bNYD1WZiegFkw4Evqblh-QgIWanwJFNVxNABP4BfQabrlAq72003qW0uln9YsUdSC-uDhiVYHpw-WH4GhoD3C-ER5rxTkD5OESfIYhk9_p6zZ1d8KV5QLJNYJQ_Y4wkQaug_JMb8nDnE--3wuQXKQwq8ma13UnSpCjjbYHDspduz-1FDjQqfHMHw1pRINIwMqDVsZ4DFEWUasXHTwuNjRwpZ1xtZEJFB4SklJd8s4Jf5gBKqluh2fI6BvFFzx8Y0mbPQSn_vAVNoTT1iQABrfnh5WEHz__7AGjyn-3HuxIEYw0g8PbiXYgpK538Q=w1140-h1518-no
9KRYSiFwS35O4CeTQ0-MDImluJ45U1Vb4FjJMrCLKwgB_nH5R1JKzJHp76WrVAAzZDIprPNkKAvldvWLNrWomZrGpbQzeU8TJV20_JAJ7Nb2s_1kOX_0xi6Bp0MFy_aZd-f9wQapatURI4r0s14ZHCI6vgbkZhHBCTujv9CLazIaRPxqajv1kQtCzX6GXylJuSemPbchOFXZOvO0bfFQDyvHD9bPi-Cm54kBCZLADatIZGhP52_bhrRsFsAdC_lznj9BEZ0eowpLrpa16WF9AsYhF4A3ip6cxGprxzQMh-NjwPhIrTe8hX0h3WKjz26F6-u5Iknz_7KE4QF-kkyexbvlX1FCKO6J4eUhQxMbWIPZxRnz20kvQGJrUAtNdt6rQlb5v0Bh7cHcuuMYg2hQyz_92KCveMx0SPrmunb7XKRktJd-mQIRZeaRnTiMVtYIoSmXKGbmZ6PheVb5v4x9MqPSWrI60ORt5nT4QXzWQ0GFIQh9jskPRKEB9Zb5ThcGQO1S-SYVQ2k7GSoqys4vW_sPmr-5gYPGfJOZAZ4hdikSg6gVjRG2r6uAyCRBIYYjnpqtJKtwdXSHpxhTPyfVRRSdvjg7VWyFU7GMcDxPM_aGEwSxSVB1fhS9iT6IkK5-zPa6ACHWMZQssBbhUhWxYY4eo_IKSu6uR2OqJx8AYw=w2024-h1518-no
9XKNIFp8K-s8WA484vkLNGk5kBXCq4Mo0IrzF9emW0LzG9O3S7cfqVoSeY5W9FYjimsQbXgsE5l-E7znNEnY8dVRFKeUK7Ap3xEzqWkqyNT-nJr_8go0pvqSdBK7c9sy5CwDaybAULLwSQdmagCgGvfynXPRxSWPFZJWlVqNGDhmmnEUJRzVIvMKn1by6MRClpDZbfDs18P-Is3NAb7hTNXfUBRR3pagi0iHRGjafHkf3Q0KUYMUsnweTO24cmFUGqts66u8HghEQVQRy1eFOqZziKi42zQ3NKVl1BSuZksK1knmAKnkXp_8IkghjmRGIJA2jbCxwlzTwaT1vLQ12yNwkcJozydvDnof9wdB7_1_-Tr4gv9Q2ktmXdDY-hCqNCX6BQbGsnAQneDjqK0gVNIaTZbLdEUixPFEgelJVgcR24BqcwjqMeHX3RsxP4bArGcS0OC0IwTaIwwaGicbfXo3W_TFPYhU2OxpLmcPGAlOIzKCkZ6N2QGqstCSX9uXwGZdT5qglYD7k7GnCG4iZyI9chqysQ9LCJ7nK49G0uKdFCmXmQ9s8vEn7gdZi7czaFZjhJRReeQRib_nWxqIVnU83eqHAWW5447x5hcevvgk-W6IN6UnXb1jq2qZ0gjGsAoX_GGyGw3DbU2u3SKiBF8JB4jNfIMSgCO9k8Z5WA=w2024-h1518-no
MJaByRHXnDujVnodEJV5fhd35HsYq5VMKkEr9yMD2PxtJKbYm4btaaOaU-f6FoHIxS3g3pWULOw8hy9wYInPZ9BE01kL-qF4Dsn8nCOgBDQ8e4-9ixmxeA4WRfmwjRZVxDUezkti4c_KEDWvTlYaG1dM9zsyJlNtIxK2cTBfpbvqiuC7N7W8uiF1hcxSvuvXvURXosoqEFM_HQwmyvH-tR2kodp6MTPLCkie9JLJPjSmV6BGVnqHTAtSVEmw2A0h4Hp1wBLBpSOAY52YAa7hUX3YyMPk2knPh6ouhC6b-sOPqltr1JMnws3uF1jqKm5Jiko-4dNzFo8bdSvCvgeveOp6fSVWkBFk8tQay6PAfv4OL_zRrJWzczphrBfhZBX6c5e6m5IAvts-BdXJFJX5gpFPraJPoK7gubI4mdO3Or60FdwQMZk1h3zrh4uh1EIkf1wGZDcUTreAA8K_E2EwpUSikxC06XXjrXHlwsKgfdyRz7PvkSjMAT1bURYvMC3PYUeyGGZL0jFVGTrF9Kktar3UFV6KkZflgYDvH0TVZpKzlQ4tPHayHo8ZboDFmtLaN701qLsVMu24nEKQ31vOLwe0D1QmlqaXzWtZLIwoZJs1ehoEMcpgbmYNEE31qEYdZrCPIklexiUyIpD9PWMpyeanGkCdqDvT521uRz3YIg=w1140-h1518-no
D_g5wp38GhMMJIAVlSVsYeY95PBfK6sMF_a9P5GqgeYH2vhJm9xoLwyP5n34K9pJrDzc34Hu4DloiUEt6SBaOqGXtFRuVL4O86ALS6IcprpSNP2k9S1CoRQoSh3E85iqaQasUE7H2_XIfcprVwXQIhm0QR-Ncz-fJF-M6QQe1PKqlHr8oZw4-Ony096KzBjBOjmI7e0IYdeo8nungMzWVg-L72eM-3CAwRW4I7PgLnVyctvikZNmb8_tTc2MYtxwev5b5O-pMS5UEetP1lP1Y5xc5791XG8CtqlBeryVN8D5y6d9jZcty6JqxYYEfaeJxHHh-ahbo8qu3UyA9PErKMxbBjmrgKJRoVLr3wVqo5WnS_eV8k9FxuJW_3fw2c_Ctu7rzPuY9wm7KU1GtOVnutPs-xDnnHkQgJZwrPGx3HV8c53kP6gZHcIKFtc8LLboGdmdm-rpfsXWZQCDWouSlz8acZkPcgsMXDvmIGijTVpkclAkEHCiqtRpwZQPdfW5rfs-dit0edzRtqwJZYDk-Z8zGAEO2KRs6umS6H3OMbvpazUoYXCU-1FsEaxRwo0ZZfCy4lYZGBFcoBAkmWuzGUA2EQf1FxQj88dzzq5yrNnJBisJ6-VTfsjcKj_ERf_zkADmJCUeCxByqtuJJZ74f9yRX6OwPGxaCJdhVWMdQw=w2024-h1518-no
l4IKOhY3saquDuyZBxuRRnO8zTwJasfgirdfx9iTnYyDohuO9XVoCBY_OrF8kit0moKaqpQ5FioOgfwepGTUdpshzsmMtK8tsLZU96ZtgML0lIRwtUnoPOUxhY2ZfS4S1vGODtYpdOJEWW-MDjR3E2_73mDlixzF80rUKo5PuHSSmwPi1ulcpkjkFdAwpZtZ7rDXUvnNRZrmTRpImIHBCY8wjV1Bz5c9rXTsJXL0qWVwim_mGODvh_vDuis1HQOJ6QraRiqvIEOzQ1XMYRkKL0SM0jF_gC7EkouldckEm-hJi-HPQK-4fBOwI4ef4K4Kxen8u3-Wa9AxFL05vaRa2C2CwUyEFEqcCKTnmHzGN4BXvM7LdDBUN4W4mxkg7mTbAU3GWYXlDxtuGU6lrGcYVA5DhUZfYEf5Mozhr1yIKNccu5ymm2QxwVZSQs8XrssxX42Spttj8fdOXs8GxquXAtpagKvLzdXLJSVWAZFYQiVPiOuU4kHfDzOyWvTYxh20CJB5E7etqO2uPoGc4TpdzBHDX8mxOSZ1cP15JvD5K5iePkTCzD__umw-Dz_1OpsELlCKi5-WMp91fRH4DMU1vsO9s0kxrq7IWx5DHiItHgbYnpgAvKlhorGz35qhkVA45HbL8CBtrjs5vB3rw_6ijZZ_lkZYDuT0ZLAGVdAW4A=w1140-h1518-no
_YHw0xF4KuU348pHTyvaxnWgqPHUqbK1cqsC4GkvOLnkMO7Wopf9L9z2gP6zcYIUPrIkibOk5cdxpk22MG_HalnCW4tRe2X2f6noObJVtjjcdDr7wOjv1mTZAQcL4GrVGr-gmXE9nS0q1xVAqLJBvWeN8EphEW8e8LqooDVeH0_FU-qBADw8qv6J_M-SOE4vZzv4vLirKoRKGBMtTH9gArnUkdzi_9eYZ9hOoMXiF693jBtFVbXtDjEKXIPoSvXdVOGh3c4u_nnUbd8ZmMifsbybNryjSoeXsSGqCwa9U2n-mM-z-K9y069Fu6qzTu1qtgxSmvDrHwr8vBzdOmyJQNcgYWkr-vKVxBkBURpyKtLVgk5m7K_QG5d5L4NPmfZ0H5hNW3Or3_mH6luhj_5VtieqGx8qRgMeVtSYlslKvbPZGfHZsues6w7y3CliefBdCnBIBYQmG4omnMGf2efHuvMBTybPrnIfXdJDVPVvEmsMOeXwDfCK97KzawcZWViHt2uopRUgVo_YIASxeqgW4fPvytPOvEKEKgFGfJwuJB_b5c1Q__3_QLwcZMqmvXd3WmWE0Bb4hoRtUzF9UUcHlO-jpnebp5MmjABwI2EjDsfnqs7-UJebxNLF-DcaySl3riLW3ODG8oj4nlQ0Wdtt05_2Wc7O1MqfcQz8E0ExfQ=w2024-h1518-no
pugslyyy
Those are good units, I have one in the Fuso. Plenty of power for the air seats, air horns, and running air tools.
banshee01
