FS: Oasis II RTT and Eezi-Awn Series 1000
I'll be glad to meet anyone seriously interested in purchasing the RTT at the Overland Expo. PM if that's an option for you.
hi there
does the rtt have a hard bottom and also as the picture shows there is the tent and awning?
Don:snorkel::snorkel:
As requested, additional pics.
Scuff from wear.
Small hole location.
Small hole detail.
Parallel mount to Thule load bar.
Perpendicular mount to Thule load bar.
Top attachment to frame detail.
Under detail.
Interior.
I have other mounting hardware to accommodate larger diameter bars as found on Xterras and FJs.
The tent has a bottom much like a tent cot.
Trampoline material and support would be a better description. It's more airy than a solid fabric cot, and tension is adjustable by tightening the bungee cords around the edges.
I have one of these tents and LOVE it!
Yes, that is a much better description. Thanks Mitch.
With sunshade/rainfly.
The fly is navy blue on the reversible side.
I might add that by mounting the Oasis with a series of GripFists or other type of quick release, the RTT can be easily removed and used on the ground like a traditional tent.
I had a machine shop make some custom mounts for the tent on my LR3. They even anodized them to match!
This makes it easy to set the brackets up on roof and if need be, drop to ground as a ground tent.
That's pretty slick. Thanks for posting.
Another advantage to the Oasis is it's smaller footprint and lighter weight, both allowing to mount other racks and gear.
nahuebsch
