FS: **SOLD**Snow Peak Double BBQ and Baja Burner + Carry case
Dr_Ble
Hello all, I recently sold one of my IGTs and hence I no longer need these items which are now for sale as a PACKAGE only. Due to the weight of these items, these are for pickup only (I can't imagine how much shipping would be for the wooden crate plus the bbq and burner plate. I always keep my equipment in tip top shape as you can see in the photos below. I bought both of these items together in Feb last year and I still have the boxes for both. So here's what's for sale:
1. Snow Peak Double BBQ box. I have used this bbq box maybe 4 times: each time with tin foil to line the coal pan, but despite this, there is some obvious cosmetic tarnishing and staining of the pan. The Box itself is amazing clean; I always wipe it down after each use. The grills are BRAND NEW (I swapped them with my two single bbq boxes) and you can obviously tell from the photos that they have never been used. There is a dent on the right bottom lip of the lid as shown in the photos but this does not alter the function of the bbq box whatsoever. When it was not in use- I actually transported it in a pelican 1600 so as can be expected; its in awesome shape. Comes with original box.
2. Snow Peak Baja Burner. I used this this plate about 2-3 times but always wiped it down after use. Have only used the snow peak canister mix through the stove as well which works flawlessly. I have the double burner stove which is larger and bulkier but decide to keep that and part with this one. It comes with the black bag and all the usual product packaging info etc. In the images, it appears that there is rust on the actual burner nozzle. This is not rust but just usual heat tarnish that is inevitable when you use the burner.
3. To carry both of these items is a wooden crate which I built which holds both the bbq and the burner quite neatly and cleanly. The carry handles are reinforced and bolted through the wood as opposed to using a screw. Also the part that carries and holds the bbq box lifts off and you can use the space below for additional storage such as cups, plates, bowls.
The cost will be 350 for the entire package.
I live in Richmond, Virginia if anyone is interested in a face-to-face transaction. Email me at SnowPeakAddict at gmail.com
Dr_Ble
The crate measures 31 inches in length, 17 inches in width and it is 12.5 inches tall. As for the weight of the kit: I think the double BBQ is 21.5 lbs, 6.2 lbs for the burner and I think the crate is about 15 or 20 lbs. So all in all: its about 40-45 lbs?
Dr_Ble
Hi RangeBrover, I would like to sell the crate with the items as I would have no use for it since it is really a custom crate to store the baja burner and bbq box.
bdpkauai
