FS TN: 1997 Ford F-250 7.3 Dana 60 *MORE PICS*
SixLug
1997 Ford F-250, just rolled over 180K miles.
Almost entirely stock. Never had a chip or a programmer. 3rd owner. No rust. No tears in the seats. Brake controller and factory tow package. 2 new batteries in May. Fresh oil change, fresh fuel filter change. A/C blows cold, heat blows hot. White with grey interior. Excellent condition. Tires are better than 90%. Never towed a 5th wheel. Driven less than 16K miles in two years. The only "modifications" done to it:
Dana 60 swap from a 1997 Ford F-350. New seals, shortened front driveshaft, new u-joints in the axles and the driveshaft, new leaf spring bushings, aligned, swap done correctly. No more TTB Dana 50 mess up front.
Barnone E-fuel kit. No more mechanical fuel pump or expensive OEM filters to buy.
Bad: One of the lights behind the tachometer is out. A trim piece on the hinge on one side of the middle front seat is broken off (I have the broken piece). That's about the worst of it.
You will be hard pressed to find a nicer OBS diesel. The modifications to this truck just make it a better truck, but it is otherwise stock and unmolested. Its 20 years old so its not PERFECT but its close...haha. Shoot me an email and I can get you more and better pictures of whatever you need. jetmechpilot(at)yahoo(dot)com
$14000 OBO. Selling b/c Im getting a second degree and I have to hit the highways a lot.
SixLug
Sorry, Auto and I will get more pictures up this afternoon. It's been a hectic week already. I will also update and organize the ad a bit better. I have a stack of receipts for work done by PO and by myself, like transmission service, new torque converter, new alternator, etc that I forgot to put in the ad. Thanks.
Breezy78
