FTS 800 wheel/rim offset
Flyrock
Hi all
I'm chasing some info on the correct offset required, to be able to have front & rear tyres running in the same track, for super single rims for my 2011 FTS 800. I'm after 15" x 22.5" to suit 385 or 425 or 445/60R tyres.
Cheers
Phil
Hi Flyrock,
I have 11.75 x 22.5 rims with 385/65 r22.5 tyres.
I have a FTS700, so, I am assuming the front diff and steering are similar, if you go bigger width rims you will possibly run into trouble hitting the steering tie-rod ends. See pic.
My rims came from Mullins in South Oz.
Dimensions are;
Outer edge of the rim to the centre disk face, 44mm. And, outer edge to centre disk face, 290mm. Centre disk thickness, 14mm.
512715
Cheers,
B
Cheers mate.
I'll look into the width measurements and make sure they fit. 11.75 might do - do you know if they can take a 425 tyre?
Thanks for the offset dimensions.
The tyre specs will have a suitable/preferred rim size width.
Others may have tried the 425 on a 11.75
B
Oops, hit the sent button too soon.
Might need to also the check the availability of the 425s, 385 seems to be a bit more common. And 385s are certainly a big tyre, see ‘Wicked Turtle’ thread.
After looking at your pic of size comparison - I think 385's will do.
With the offset measurements you supplied, do your tyres run in the same track, front to back?
What was the part number from Mullins? Was it 710-545?
What rubber did you end up going with?
Cheers
Phil
Don’t know about the part number, I originally purchased rims ‘off the shelf’ from Mullins, did a trial fit, only to find out that the offsets weren't correct. I returned them and sent Mullins the correct dimensions. These are the dimensions detailed in previous post.
This gives the front and rear the same track.
Before putting down the cash, ask for the offset dimensions. See what they come back with?
Tyres are Hankook AM15, they have an all terrain pattern.
B
ELShockley
