Hi guys
I have a 1995 E350 with a 7.3 in it. Love the van but have been having a fuel leak rear its head once in a while. This past weekend I ended up diving into it and determining that the small sensor on the back of the fuel bowl, I believe its call the flow restriction sensor or vacuum sensor was leak. I replaced that, dried up the valley of fuel and proceeded on my way.
The van didn't seem to be leaking anymore, drove probably a hundred plus miles with no problems. Parked the van for the night and had a spot on the ground again. I pulled off the dog house to check the sensor and one line I replaced and all is dry on the back side of the engine. The leak seems to be coming from the bell housing area, but I cant possibly see where it is leaking.
What are thoughts on the front of the fuel bowl having a problem? Do I have to pull the turbo and such to even get the fuel bowl out? No sure how to proceed with this and any input would be great.
Thanks
Thanks
