I replaced the stock 33 gallon tank with a 50 gal plastic tank from Northern Tool and Equipment I used the old sender. The tank is plastic, easy to drill new holes in it... I did have to do some bending on the float arm to get something close to an accurate reading but the sender was calibrated for a cylindrical tank and the new one is rectangular, so sometimes the reading seems a bit funky. After mounting it I poured the 9 Gal of diesel back into the new tank and nothing showing on the gauge. I guess I didn't bend things enough. If you are going to have an error on your gauge, I would rather it show empty and you still have several gallons of fuel in there. Fairly common on fuel injected vehicles now to read empty while there is still several gallons of fuel in the tank. Of course, I had to run a ground wire so the sender would work. I've thought about mounting the old tank with the proper valves and return lines somewhere on the vehicle, over 80 gallons of fuel on board would be nice until you had to hit the gas station. You are going to be burning that fuel anyway, so it just means you can get to a place with a better price, hopefully. I complain about fueling, A friend drives over the road in his semi. Two 150 gallon tanks so that's got to put a hurt on the old wallet. Sorry about the rambling,, lack of sleep does that.
