I will ask the age old question, How hot is too hot ?
Vehicle: 2008 Dodge Power Wagon. 10.5" AAM 14 bolt rear & AAM 14 bolt 9.25 front. Both with electric lockers inside.
The reason I ask the age old question of how hot is too hot: I have recorded temps all over the board with my trucks. I use a laser infrared thermometer. I have tried to verify it with other infrared thermometers. They all read the same, so I am assuming it is somewhat accurate. Vehicles I have used it on: 2000 dodge dakota auto, w/360 & 3.92's towing a 3000lb tent trailer, 2004 dodge Ram 2500 w/Hemi, auto w/4.10's towing a 10,500lb toyhauler, 2008 Dodge Power Wagon w/G-56 manual, 4.56's towing a 10,500lb toyhauler & now a 3500lb 18' single axle camper.
I have bought all these vehicles new. Some temps I have recorded while towing: 195*, 285*, 315* & just recently towing the 3500lb camper w/Power Wagon 256*. I have used all kinds of different oil: Mobil1 full synthetic, Mopar full synthetic (currently in Power Wagon when recording 256*), Royal Purple full synthetic, Amsoil full synthetic & others. I will not say which oils recorded which temps because I don't want to get into a brand loyalty issue here. But needless to say, I am not very happy with any of them. None seem to last more than 11-12,000 miles in the Dodge trucks I have had. My current truck (08' Dodge Power Wagon) has recorded a temp once of 315*F. I changed the oil as soon as i got home after that trip, but what the gives here ? Are these temps normal ? I do not think that they are. I am thinking the 315* temp is what did in the rear locker actuator inside the axle. It was covered under the lifetime power train warranty but i would like to avoid this again. I have changed the diff fluid 4 times in 43,000 miles on my Power Wagon.
I ordered a Mag-Hytec rear diff cover today & will install that myself, but even if it does reduce the temp by 25-50* as claimed, I am still running too hot I think.
All trucks were brand new when I got them. Yes, fluid was up to specs. No, there were no leaks. When I read people saying their rear diff temps are 100*-130* when towing, it makes me scratch my head. I have recorded 195* when empty, using top of the line oils of the proper weight. I have even tried thicker weight gear oil. No difference.
Input please, not sarcasim.
