Gear's Baja JK Thread
Ok, here are a couple of photographs of the lift installed. Enjoy, I know I am. The ride quality is 100% better. :smiley_drive:
47b8dc07b3127cceb5ffb244775a00000026108EatWzFu0cO
47b8dc07b3127cceb5ffc59b372600000026108EatWzFu0cO
Hope to see you on the trails soon Mark. Thanks for the compliments. Oh and Sven I have no reason to believe with a little time your JK will be just as nice. It is just amazing how much time it really takes to build one up.
well, the problem is that i cannot do everything i want due to tech. inspection here in germany. and i don't know anybody. i'd like to develop a roof rack but i can't pay to have it done by somebody. and here are very few people who have shops...
you can say that loud....
FourByLand wrote "Have you had a chance to test the flex at all? Glad that you didn't compromise any ride quality. "
Not exactly. I am having some difficulties with the rear swaybar and the very deep backspacing of the AEV Bridger wheels. Poly Performance has designed a very nice shock relocation bracket that moves the shocks up 2". Unfortunately with the wheels so far inboard the rear swaybars need to be moved to the inside of the swaybar to clear the tire. See photographs. For now I have crossed up the driverside so the bottom is on the outside and the top is on the inside. It is working but does not look very good. Poly Performance is suggesting I get wheel spacers. Not really interested in doing this. My thoughts are to remove the shock relocation bracket and reweld new shock tabs on but move them up and out of the way. This if done right would allow me to move the swaybar to the inside on the bottom.
47b8dc23b3127cceb4e0938f351a00000025108EatWzFu0cO
Poly Performance Rear Shock Relocation Brackets.
47b8dc01b3127cceb538c6bb44c200000025108EatWzFu0cO
This photograph shows the rear swaybar link crossed up. The top is on the inside and the bottom is on the outside. You will also see that the new shock bracket is braced off of the swaybar tab. This is why I think I need to reweld new tabs on. So that I can make room for the swaybars to be moved to the inside. This is really only necessary for the driverside.
47b8dc01b3127cceb538c6a744de00000025108EatWzFu0cO
This is a close up of the bracket with the swaybar crossed up. Eventually if all was good you would be able to cut off the section below the relocation bracket. Effectively gaining 2" of ground clearance.
Well any thoughts!!!!!!!!!!
On a lighter note: I was able to get my sea kayak out in the water today. Temp. in the high 70's. The rack worked great!
47b8dc06b3127cceb5e7f1daaeff00000026108EatWzFu0cO
47b8dc06b3127cceb5e7f1c6aee300000026108EatWzFu0cO
47b8dc06b3127cceb5e7f1c12fd400000025108EatWzFu0cO
Oh and the boys had fun with the kayak as well.
we had that too (VERY unusual for here...) and i went topless a couple of days ago:wings:
what tube size did you use? what wall width? any movement with the kayak onboard? do you happen to know the rough weight of your rack?
so many questions...sorry!
thx
sven
XXXpedition wrote "what tube size did you use? what wall width? any movement with the kayak onboard? do you happen to know the rough weight of your rack?"
Tube size is 1.5" on the side bars that go from the A pillar to the rear bumper. The cross bars are 1.25". We were trying to save a little weight plus the span is not as long. We used these disconnects on all of the cross members.(see photograph). I think the thickness on the tube was 1.25 cold rolled tube does that sound right. I'll ask Joe the fabricator when I talk to him. The rack is solid with the kayak. I get a little side to side movement in the back when I shake it with my hand. I wanted the cross members to be removable so the hard top could easily be taken on and off. This presented a little problem when trying to triangulate the corners to make the rack ridged. I am hopping that once I install the top plate(flat piece of aluminum or King Starlite XL) this will anchor all the corners and tighten up the rack. Weight I did not get, but it is lighter than you would think.
47b7d739b3127ccebc5121e83d3a00000026108EatWzFu0cO
Here are the quick disconnects for the cross members.
47b7d739b3127ccebc5121ffbc1d00000026108EatWzFu0cO
Quick front shot.
47b7d732b3127ccebbc9d6c3e15b00000026108EatWzFu0cO
Here is a shot of the 1.5" tube that runs from the A pillar to the rear bumper. Notice there are no cross members installed.
47b7cf09b3127cceb0a56b07432000000035138EatWzFu0cO
Ladder and at the top you will see a pipe with a bend. This pipe has one removable bolt that goes to the side bar. This was used to triangulate the corner. The problem again was I need to be able to remove it for the hard top.
47b7cf09b3127cceb0a56a8a820500000026108EatWzFu0cO
Another shot of the triangulated corner.
47b7dc26b3127cce813bc0149d9500000016108EatWzFu0cO
Here is my old rack with the aluminum on top. Makes for a great platform to stand, sleep, and store things. The new rack I am looking at using King Starlite XL(Plastic foam core sheet)
thanks for the detailed answer!
just for interest: why didn't you take a perforated aluminum?seems to me it would have several advantages: lighter, easier to hook stuff to, etc.
jgwarren319
