sidecardog
Hi Guys,
I have a parasitic draw issue and I am at my wits' end trying to fix it. Any advice would be greatly appreciated.
I have a 2002 Montero Limited. All of my electricals are stock with the exception of a CB radio with power tied in to my cigarette lighter, and installed 9 years ago. I have not had any electrical issues of any kind prior to this. I woke up one morning a few weeks ago and the battery was dead. I had it tested and it tested fine. After two more mornings of dead battery I ran a parasitic draw test and found that my hazards/blinkers circuit was drawing 3 amps with everything turned off. If I remove the fuse for that circuit the draw drops to .17 amps. This still seems a little high to me but I have not been able to find another draw.
I have disassembled most of the dashboard and removed the left fender to check the wiring. I have not found any evidence of wear or bare wires and all wires look in excellent condition. My temporary solution has been to take the fuse out whenever I park at home for the night. I have forgotten to do this on four occasions, and on one of those occasions, the battery did not drain. I cannot identify anything that I did differently on that night.
It is my understanding that checking the hazards and blinker relays is not an option because they are built into the ETACS unit. Can someone confirm this for me?
I have disconnected the hazard switch and there was no change to the draw.
I have disconnected the blinkers switch and there was no change to the draw.
Does anyone have any suggestions for what to check next? I know that I can add a switch to the fuse and turn off the circuit from inside the cab if I don't find a solution but was hoping that someone out there may have found a fix.
Thanks
Matt
Thanks
Matt
