01MontyLtd
Hey Guys,
Long story short, my starter went out so I ordered a Power Select/WPS 17131N (new) from Rockauto.
After installation, I made sure all bolts were tighten/ heat shield installed properly.
Start the engine, then I got constant loud grinding from the starter.
Note: I didn't have this noise before.
Comparing side by side, I noticed the position of the drive pinion on OEM (Bottom of the pic) is sitting
much closer to the frame, and seems to be smaller in dimension than the Power Select starter.
Could this be the product issue?
![Starters.jpg Starters.jpg](https://expeditionportal.com/forum/data/attachments/307/307149-d566232e7ff3d9b43a4cdc0861bacc97.jpg)
![Starters2.jpg Starters2.jpg](https://expeditionportal.com/forum/data/attachments/307/307151-4d59a1a751f1578d951adcfaf883425d.jpg)
I'm going to re-order another starter, but I need some opinions on which one to get.
![Montero3.5_starter.Rockauto.JPG Montero3.5_starter.Rockauto.JPG](https://expeditionportal.com/forum/data/attachments/307/307150-5e6e85a773994baad76d0413d7fb1d2b.jpg)
Let me know what do you all think?
