The Adam Blaster
Hey everyone,
I've got a '98 XJ and I just recently had an ARB front locker installed, and the little ARB compressor as well.
The compressor was installed in the spot where the stock spare tire normally gets mounted, on the driver's side. I talked with the installer about this issue and preferred that the comp. stay inside the vehicle rather than under the hood to keep it cleaner, and hopefully extend its life that much longer.
I'm going to make a shroud for the comp. to protect it from any shifting cargo back there, but I was thinking it would be nice to have a smallish air tank to hold more air, and possibly run some low-volume air tools. I'm mostly thinking it would be nice to have my air-impact gun for changing tires rather than doing it all by hand on the trail if I happen to get a flat.
I'm thinking a great place to mount the tank would be right on the window sill just above the tank. It would have a very short run of air line, and the whole setup would be in one place, which I like.
So, considering the space in the area I want to mount the tank, what would you guys think is the best size for this application? And if there are any relatively inexpensive products out there that would work well for this setup, please let me know.
EDIT: Editing for lack of use of the "h" key in the word "the". I'm about ready to pitch this work keyboard out the window...
