Been workin on the LX 450.
Pressure washing the exterior and cleaning the interior took 8+ hours. It was NASTY!!!
Pics below give an example of the interior before and after. Looks great inside now. No real issues with the leather seating. Cleaning and feeding the leather hides sure does help. Razor bland on the glass to clean it, scrub the carpet, treat the weather stripping and more. Still have to clay, buff and polish the exterior to make it look nice and repaint the front and rear metal bumpers. The truck has never been wrecked and never had any paintwork. Should polish nice and look good when done.
Spent a lot time under the hood.
Pulled the plugs and sprayed a little fluid in the cylinders and let set overnight. Manual cranked the engine over by hand. Went to crank with the starter and the starter Bendix will not engage. Time to pull the starter! Starter sent to our local starter/alternator guy.
In the meantime I spent time under the replacing most everything including new battery, oil & filters, air filters, radiator fluid, radiator cap, thermostat, radiator and heater hoses, washer fluid, plugs, wires, distributor cap, rotor button, PCV valve, front and rear diff fluids, transfer case fluids, F&R wiper blades, replacing 1 cracked glass headlight assembly with used off EBAY. Still need to do the brake fluid. Will git to that when the truck starts, stops, runs and drives!
Hope to PU the starter from the rebuilder this weekend. Ya I know why not git a new one. I'm supporting the local guy in business for years here.
The matching Michelin tires are only 16 years old. Ya'll think they will be OK???
Below is are some pics of the 450 now that interior is cleaned. One of the rear seat before cleaning and one after. Pretty much is representative of the rest of the interior. The after pic was before "feeding" the leather. The seats look MUCH BETTER than the pic shows!
Thanks for the suggestions about buying Toyota parts. That's what I have been doing for Toyota unique things so far such as the new radiator cap, PCV and thermostat.
More to come when we see if this Heap starts, runs and drives!!!
