allyncooper
I have a 5' x 7' enclosed trailer I'm modding out as a camper/expo trailer. It currently has 14" wheels with 195/75/14 tires and a dropped axle (puts the hub center 4" above centerline of axle) Axle is mounted on top on leaf springs. This gives me about 4" of clearance from the axle u bracket. Obviously I want more than that for intended use.
I plan on changing the axle out to one 2" wider with brakes to accommodate 31/10.5/15 tires to match those on my Ford Ranger. I want off road clearance capability but nothing extreme (no rock crawling, etc.) sticking to established forest service roads. My question is how much clearance is recommended given my stated use. Changing out the axle with a straight (not dropped) axle will pick me up another 4", and with the bigger tires another 2", for about 10" clearance. However if I mount the axle under the leaf springs I can pick up another 4"-5" of clearance for about 14" or 15" clearance. Another factor is I have a hitch carrier I can install on the back of the trailer, so with that and trailer tongue I'm actually about 13' total length on the setup when I have the carrier on. (I'm thinking I might want higher because of this).
So open for recommendations based on similar experiences of what I need for clearance given my setup and intended use. TIA
