Looking to start a trailer build soon and I'm going to be using some half torsion axles. I have a 5th gen 4Runner that I'd like to run Toyota wheels on the trailer as well to have spares on hand etc.
Most of the 2-3,500lb axles come in a 5x4.5 bolt pattern. Instead of running wheel adapters, I'd like to just have the proper idler hub assembly to start.
The "bare" axle set I'm looking at are these:
www.truckspring.com
The problem is finding an idler hub that'll work to be able to run 4Runner 17" Off-Road stock wheels. I talked to someone at etrailer.com and the only ones they have fit up to a 16.5" wheel...
I'm waiting to hear back from Truckspring.com to see if these hubs will work:
www.truckspring.com
I know some people have experience with running Toyota 17" wheels on their trailers (and people with general trailer axle knowledge) so just trying to pick some brains here.
FlexiRide Raw Half Axle | Brake Flange and Adjustable Arm | 3,500 lbs. Capacity
FlexiRide FR-3500 B LUBE universal trailer axle kit has a brake flange, adjustable arm and 3,500 lbs. capacity. Call Steve at 1-800-358-4751 or visit TruckSpring.com.
![www.truckspring.com](https://www.truckspring.com/favicon-32x32.png)
Idler Hub | 6 X 5.5 Inch | 3,000 lbs. Capacity
Flexiride 6 X 5.5 inch idler hub ID-82655-5 is designed for 6,000 lbs. axles. Call Dave @ 1-800-358-4751 for help with idler hubs or visit TruckSpring.com.
