texas taco
Has any one used a fumoto drain valve on your oil pan. I am thinking about getting one. I am sceptical of a valve hanging below the oil pan on my 03 double cab tacoma. What your take on this?
What size drain plug does your truck have? Mine was a 18mm so I am probably about 12MM so over my last engine its a wash. 12mm plug I would expect some extra time. That would be offset by the fact you have less clean up time. If you keep a 5quart oil jug you can drain right into it if you get the version with the nipple.offroad_nomad said:How much time does it take for the oil to drain with the fumoto drain valve?
I never timed it but it does take a little longer. No worries, it gives me time to drink a root beer and get the rest of my stuff ready. The benifits out weigh the longer drain times.offroad_nomad said:How much time does it take for the oil to drain with the fumoto drain valve?
Bella PSD said:I can drain the 15 quarts out of my 444 CI in about 4 min.
Louie
A couple of things.Grim Reaper said:It points right at my front diff. Its a shower when you pull the plug.
I had to notch a rib a little in the diff housing to clear th nipple but well worth it.
I only got one bath. I let the toyota dealer (had a cupon my mom didn't use on her RAV4 get the second bath. I warned the kid. LOLDaveInDenver said:A couple of things.
Pictures, Grimmy? I looked at the drain plug, front diff situation and have been scratching my head for a few years trying to come up with how to fit in a Fumoto.
Second, the oil bath problem. Save your old cereal boxes and use them as a oil chute. I find the medium size (I want to say 22 ounce) Frosted Flakes works perfect. Open it up, put a slight crease lengthwise and hook the top flaps over the diff. Then open the plug, you get about 10 seconds of high flow and the cardboard will get slightly oil soaked, but keeps the top of your diff clean.
