Heater Core Leaking
Howah
I'm in need of a heater core for my 95 sr at the moment. What year, make, model would fit or can someone look up the part number for me?
HARABAS
You know, for what it's worth, I had a leaking heater core about 5 years ago. It was leaking into the driver side foot well and became an air freshener I, nor my passengers, didn't care for. Mechanic said it needed to be replaced and recommended against those quick fix solutions. Not having the budget nor the time, I went ahead anyway and poured in a radiator leak fix solution (the one with the glittery bits) with the intent to replace it at a later date. To my satisfaction, the leak stopped, the hot air came out of the vents hotter and I haven't had the need to replace it (again, that was 5 years ago).
Not sure if I was just lucky or if the particulars are different, but I figured I should share my experience.
Best of luck with your Montero Challenge of the Moment!
SoCalMonty
I blew a headgasket and cracked a head on the Volvo in my sig...25psi and over-revved on the highway against a new Camaro SS (whoops!). I used KW Head/Block Repair to see if it would buy me some time. I ended up driving the car like that for another year...it worked for me. I was still running 18psi on it too. lol.
It's worth a try, seeing as how the heater core replacement is a huge PITA. It just depends on the nature of the leak and how bad it is. Though, I had oil in the coolant and vice-versa, and the KW stuff worked for me. Maybe a liquid repair will buy you some time at least if you don't have the means to tackle the heater core immediately.
Howah
Within an hour I got to the core
Upon closer inspection, I found the culprit hose and not the core itself. Changed it out and no leaks afterwards.
HARABAS
Holy moly! My compliments on the dash removal. I haven't disassembled mine completely, but even half way off, it was troublesome.
Well done.
Howah
Putting it back together took much longer...
One thing I should have done when installing new hoses were to use some sealant just for extra protection.
It look just like a vehicle from the junk yard.
mattyak
Howah,
Thanks for the pics. Im in for the same surgery. Im hoping mine is a leaking hose as well.
I haven't had any fluid visible on the inside but when I use the heat I get all fogged up inside and the heat doesn't work.
off-roader
Unless you really screwed it up it probably won't be needed. Let's face it, you're talking about a heater system that's 2 decades old and I'd be willing to be has the original hoses to/from the heater core.
plh
If anybody does end up needing a heater core, I have access to new OEM Mitsubishi for pretty reasonable prices. PM or email for details. nsm.paul(at)gmail(dot)com or use the contact form on the Tuffpans website.
Sfreeman
