Hello from Salt Lake City! New to ExPo.
medicfernando
Hi guys! I am new to expedition portal. I have built many rock crawlers and overlanders and my latest project is a 95 RRC. So far it has 3 inch OME springs, Terrafirma rear shock lowering mounts, Terrafirma long travel shocks and Terrafirma caster corrected radius arms. Next up, bumpers, sliders, gears and ARB's front and rear. Ive been thinking about forming a group of local overlanders to do trips to Moab and occasional runs nearby. If anyone is interested, let me know. Heres a few pics of my Rover. Cheers all!
blue bomber
Welcome to madness. Nice rangie, I have seen quite a few rangies built up,inspirational. In a moment of weakness, the boss(wife) mentioned that it should be set up for family Offroad trips. I might have to build mine?? Sadly she doesn't get much use these days. Presently the series is the preferred ride. Great shots of your truck.
Cheers, Matthew
medicfernando
Thanks Mathew. I have had more "rock crawler" type vehicles in the past. Like you, my boss (wife) also asked for something more civilized and comfortable to travel and overland with a pop-up trailer. My reply, "so I have to build a new vehicle, twist my arm. How bout a Land Rover?" Building them is half the fun.
maxingout
You guys up there in Utah spend a lot of time driving on rocks. I'm wondering how long those locking differentials survive when climbing and driving on rocks? What is the life span of a transfer case on a RRC with everything locked up?
blue bomber
You just unlock the center diff on flats and use the lockers before needed, minimizing bind and shock loading. My series has no center diff,as long as you have some tire slip every so often bind is not an issue I have been running arb's for 17 years. Completely reliable, original air compressor too. Granted I only use the compressor for the locker and not for airing up tires. I have re-geared and resealed once.
medicfernando
My RRC is fairly new to me so my experience with it is limited. I agree with Bluebomber however. After 20 years of four wheeling in Moab I can tell you that it is about using the lockers when necessary (before you get into trouble and need them) and finesse with the right foot (gas pedal). I have yet to break an axle or a transer case in any vehicle after having done the most difficult trails in Moab. Cheers
czenkov
Welcome
Good looking RRC. I don't think I have seen that one around. Where did you get it? Do you do your own work or will you be looking for a mechanic? I like to do my own work but for some of the more complicated stuff I have a good mechanic.
Also, check your PM.
atancreti
Hello! Welcome! I love Utah! I am looking at attending the University of Utah for college with a engineering degree! Are you going to the rally in Moab in June? I will be there. Also, If you need any parts for your range rover: Talk to Lincoln at http://www.roverbones.net/ His number is right here: (505)-263-2136 He is a great reasonable guy. He doesn't price gouge!
Welcome again!
baja5337
Good looking Rangie. I think I saw that for sale on KSL not too long ago, I drooled over it. Thanks for buying it before I was too tempted ;) I don't need another Rover right now
medicfernando
Hey baja 5337, I had been looking for a while for a good clean RRC and found this one on KSL.com as mentioned. Since I got it I have completely redone the suspension and a few other things. Everything works and she runs great!
Atancreti, I am going to the rally in Moab. Ive been going to Moab for many years. Thanks for the line on parts. Cheers guys!
maxingout
Interesting. From our time running in Arabia, we never ran with everything locked up on hard surfaces. People used lockers in sand, but that was the only place.
In ten years of running in Arabia with other Land Rovers, I have seen one stripped wheel hub, one broken front half shaft, and a broken arb locker rear differential. A few years ago I was on a Hummer forum that reported on the Moab adventures of a large group of H1 Hummers. They put all of their broken gear on a drop cloth at the end of the meet so that everyone could inspect the carnage. There was at least one transfer case and some half shafts that did not survive.
I am not used to off camber driving with things locked up. It goes against everything I learned in Arabia. I guess I should get an older truck that I can fix, and then try some of the off camber diff locked rock climbing. Maybe I might learn something new about how tough the trucks really are.
In Arabia, if someone broke a major piece of gear, it could have been a show stopper on a week long trip. Although we ran heavily loaded vehicles, we ran them conservatively because we did not want to ruin the trip for ourselves or anyone else. When you are doing expeditionary travel, you have a phobia about breaking stuff. If you are rock crawling with help readily available, you may not worry so much about breaking stuff when you make a mistake (if you don't mind fixing it or paying someone else to fix it.).
colvere
Very Nice
That is a very nice looking rig, I love the clasics. I am in Twin Falls a few hours away, hoping to get to Southern Utah this spring.
Mcoleman
