fairweather
Hi all,
LTLFP ,long time lurker, first post
I am looking at a 1994 Ford E350 that has a 4wd conversion and am wondering if it is possible to find out who did it by the way it was done?
Front has leaf springs over the axle with the shock mount on the plate on top of the leaf. It is a tiny little shock but looks as if a larger one could be mounted next to it (in front of). Shackles are on the rear of the leaf.
1356 Borg Wagner transfer case, front drive shaft held on with the little loops rather than a flange.
Rear leaf springs with a 4" block between axle and spring.
The owner says it was a shop in SLC but has no other info.
Thanks for any insights,
Tom
Tom
