Salmon
I think it's time I admit to myself that I screwed up, and I need help. I don't know why I have such a problem with wheels (and other associated componentry) but they seem to be the one part of my truck that kicks my butt time and again. I've spent hours googling the topic, I've read every build thread I can find relating to Tacoma wheels, I've read some very informative discussions about wheel measurements, etc. And despite all this, I think I've just made what will probably end up being an expensive mistake. It's time to admit I'm lost and ask for help.
Here's my situation: I have a 2004 Tacoma, with Deaver 10-leaf spring packs in the rear and Icon coilovers in the front, with otherwise stock suspension components (A-arms, etc). I also have upgraded to OEM Tundra front calipers. Total suspension lift is somewhere around 1.75". My goal is to maximize ground clearance while maintaining as much reliablilty and road-handling as possible by minimizing the suspension lift. With the type of driving I do, having crazy articulation is not really a big deal. I have done a fair amount of fender trimming already. I would like to be able to run 255/85 R16 BFG MTs (the newer style tread pattern), because I already have those tires in my garage. For my next set of tires, I think I will probably pick tires a little shorter and wider.
Here's how I screwed up already: I did all my research (or so I thought), and bought the aforementioned tires along with five 3.5 backspaced 16x8 steel wheels. I had a local shop install tires on wheels (thus voiding the return policy), and brought them home, only to discover that the wheels will not clear the new, bigger calipers. It's not even close, so I suspect they would not even have cleared the original Tacoma calipers. To make matters worse, I scratched the crap out of the back of the new wheel in the process.
Here's what I'm thinking: I really don't get the hype about all these styled wheels everybody puts on their offroad trucks. I'd actually prefer to get a set of simple black painted steelies. It seems like I should be able to buy new wheels like that for about $50 apiece. Am I delusional? Is there some sort of method to actually figure out exactly what will fit my truck, besides trial-and-error? Is there some reason that I should be interested in fancy schmancy $150 wheels (besides looks - to each his own)? Should I be worried about the wheel's strength under a non-rock-crawling 4500-lb truck?
Here are some possible solutions I'm considering to salvage what I can from this SNAFU (Somebody, please take pity on me and help me out of this mess): Can I just buy OEM Tacoma spare wheels to use full-time? Could I just put the taller/narrower tires on the stock alloy 16x8 wheels, without them rubbing the frame (fender trimming makes the frame the only interference I'm concerned with). Are there any other sources of wheels that I am not aware of, that might be a better option? I did shop craigslist and other online sources for about 4 months before I pulled the trigger on these new wheels, but never found anything that looked promising.
Note: I am not interested in running wheel spacers or grinding the calipers down. Enough people have safety concerns about those options that I am not willing to experiment.
Other note: I will probably have 5 nearly-new steel wheels for sale this Fall when I get back from deployment. One wheel has scratches all over the back side. Steel with black powdercoating, 16x8, 3.5" backspacing, 6 x 5.5" bolt pattern. Minimal clearance in the caliper-area. Sorry, I've been away from home several months and can't remember the actual brand or model.
