sixstringsteve
Since I'm just waiting around for my tacoma to sell, there's not much I can do but sit, wait, and plan my next rig. Help me think ahead and try to anticipate some of the things I need. I've talked with Chris quite a bit over at U-joint and he's been very helpful.
I'm a former rockcrawler, and I like stuff overbuilt. yes, 37s are overkill for most trails, but there'll be a few trails where I'll want the ground clearance, look, and ability to air down a ton.
Goal: van similar to vanaconda (reg size with windows, 7.3L diesel), 37s with minimal lift (4"). D60, 10.5 rear end, 4.10 gears? Crossover steering.
Ujoint Conversion kit
Front End
Front hangers - Included in Ujoint kit
Front springs - Included in Ujoint kit
Front Shackles/bushings Included in kit
Ubolts Included in kit
Front shock mounts Included in kit
Front shocks - included in kit
D60 front axle?? $700-$1200 Used off a 99-04 F250, F350
Warn hub conversion $219?? Included in kit?
Crossover steering arm/knuckle included in kit
Sway bar links Included in kit
Hydro assist kit ??? where do I buy this?
Drilled and Tapped ps box $200??
Crossover Steering Included in kit
Steering stabilizer - Included in kit
Tie rod/TR ends? Necessary?
Extended brake lines Included in kit
Front frame support Included in kit
Drivetrain
Tcase $500-700 Nv 271 – will this mate up to the 7.3L?
4x4 tranny output/tranny work ???
Driveshafts $500 each
Crossmember Included in kit???
t-case shifter assembly for vans Included in kit?
Wheels/Tires
37x17” tires $2000
Wheels $500-800 Cragar soft 8s. What's the backspacing on vanaconda?
Rear End
Leaf springs Included in Kit
New shackles??? ???
Ubolts - keep the stockers
Shock mounts - keep the stockers
Wheel spacers - included in kit
Other
Fuel tank shortening kit? Included in kit
Paying a welder to shorten my tank:
Is a new MC required for the 10.5 rear? What about the 550 knuckles/brakes?
Wish-list, but not in the budget
Ujoint font winch bumper ???
front winch
interior stuff like shelves, seats, sound proofing, etc.
What am I forgetting? I'm sure there will be about $300 in extra nuts and bolts and random parts at the parts store. I'd like to have a laid out plan before attacking it.
Front End
Drivetrain
Wheels/Tires
37x17” tires $2000
Rear End
New shackles??? ???
Other
front winch
