High mileage and trips
That's not a high mileage for an 80 series, really.
We used a LC in Tanzania which had 530,000 km on it: the speedometer was not working and we asked how long ago it had failed - the answer was "No idea, it wasn't working when we got it 6 years ago".
We met a traveller in Argentina whose LC had over a million km on it.
However.... expect to have to fix stuff, and be prepared for failures. Our 80 series, in two years of ownership with 325,000 km on it at the end of this period, had the following failures, despite rigorous maintenance:
- miscellaneous electrical problems during a week's travel, finally resolved by a great specialist in Victoria Falls, however during the week we were stuck several times and needed "first aid" fixes.
- A/C fan motor wore out - replaced after a couple of months wait for a new one from Dubai - we spent the time travelling with no A/C, which was OK but not as comfortable as preferred in Southern Africa.
- Radiator exploded - we found the only replacement available (new or used) in the country and replaced it - rented a Ranger for a week while this was being done.
- Front differential failed - fixed in Kampala, which took a week, during which we rented another 80 series. The failure was in Murchison Falls and to get to Kampala we disconnected the front prop shaft and the hubs, which meant that the hub seals were not fully protected (despite temporary covers). As a precaution we replaced the seals, but.... the new seals which we could find were not OEM and one seized after only about 500 km, shearing the hub. So we needed a new hub and this time found OEM seals and replaced both.
My point here is not that you should not make the trip, we were happy with our vehicle and had great travels in it, however you should expect to have to fix things, which may mean a long wait, and you should always have a Plan B (and a Plan C).
But in N America parts availability for these rigs is getting very slim vs Africa & S America where they are everywhere and people are familiar with the rigs to repair.
Exactly correct. US Gov't publishes on the road survivability rates by year. 1997 Model Year Light Duty Trucks (last FZJ80 sold new in USA) it is estimated that 15.3% remain registered. Perhaps the percentage of Land Cruisers is slightly higher, but probably not by a lot.
My (failed) intention was to suggest that it's a good idea to make the trip, but to expect to have to fix stuff. If this is within your abilities then it's a matter of access to the spares, if not it's both spares availability and competent people to hire.
I do appreciate that the situation in the USA and Canada is not the same as it is in much of Africa, Australia, etc., so this means that parts availability and experienced workshops will be more limited and hence that the time one might spend waiting on spares will be longer on average and that the distance to a competent workshop may be greater. Even so, courier services from suppliers (such as amayama.com) mean that spares can be shipped in days, whereas in Africa (for example) it may take weeks, for local reasons.
I'd check the fluids, the lights, and the tire pressure and roll. Granted I'm the guy about to roll my '99 D1 back up into to Ontario for a funeral in January because I don't trust my wife's newer Audi Allroad so far as I can throw it regardless of how much time or money I or a master Audi technician spend with it on the lift. Current issue seems to be communication of the fan control module which really makes me appreciate the 'rover's simplicity.
UPS for parts. FJ80s are super simple to work on. I would rather work on a FJ80 then my F250. F250 parts are heavy?
Newer vehicles can have similar headaches. My buddy had a '18 F150. He was leaving town with his wife and 2 kids heading to Mexico when his truck went into limp mode. His truck sat in the dealer lot for 8 weeks waiting for parts which ended up not fixing the issue. I guess you could argue he at least got a free Lincoln suv loaner. They took the loaner to Mexico. The dealership was pissed ?
Well cared for Land Cruiser = Send it!
It's an LC......duct tape, welding rods, jumper cables, bailing wire, tools, JB weld, tire repair, gas, oil, water, etc. and good to go.......you won't need any of it but, you"ll have a great adventure.....
My 87 FJ60 with a over a quarter million on it is still the go to travel/adventure rig.
I have two J80s, one with a pop-top. The key is preventative maintenance. If you've done preventative maintenance across all of the systems, then it should be good to go with a significantly reduced risk of unforeseen failures. I still do long remote trips in mine, Baja being my favorite, where there is effectively *zero* parts availability. There's a particular satisfaction to returning home after three weeks of remote touring in a 30 year old truck.
The j80 is uniquely suited to carrying large payloads and multiple people on technically difficult and brutal/jarring dirt roads to outdoor living destinations, like in Baja. If I were choosing a rig for two people traveling to AK, which is all paved and maintained dirt roads, it'd be a leveled single cab long bed F-150 FX4 with an ecoboost (mileage), a 36 gallon tank (range). a payload package, and a lightweight pop-top slide in (heater and indoor living space).
Do it! You'll be fine. We're shipping a 340k mile 100 series to South America this year. I'm at the point where I look at other more expensive vehicles in terms of how much shorter the trip would be. $$$=time.
M meadow build
