HiLift mount for a DII?
R_Lefebvre said:
Yeah, after talking with some other guys, I'm starting to think it's not the first thing I should be getting as Bill Burke suggests. As mentioned, there's nowhere to jack from on the stock vehicle.
I mainly wanted it for winching, but given the difficulty of mounting, maybe I should just keep saving for a winch for now.
Being highly geeky, I did a lot of research to outline the plan for my mods. Seems the majority of DII owners suggest the same progression for what I would consider "moderate mods."
1) OME or mild Rovertyme lift
2) New treads. ( New tires and a small lift make a DII a new beast)
3) Front bumper to house winch. (for those of us stuck with traction control, this seems like smart money)
4) Sliders (yes, I own a rocker panel ding) PLUS - This is where the Hi-Lift enters the picture.
Beyond that, the sky is the limit, but most DII owners agree those are good starting points.
Well, I decided not to lift it, or if I do it will be minimal. I'm trying to keep the CG low. I figure I'll need new springs when I put the winch bumper on, so when that happens, I'll be shopping for some heavy duty springs with a higher rate, and as little lift as possible. Maybe 1". I don't plan on anything extreme with it as long as it's my daily driver.
I already got the new tires. Traded the 18's for some 16's and put 245/75/16 Cooper ST-C's on them.
Front bumper, rear bumper and sliders are in the planning next. Maybe a snorkel too. Probably going to be custom made as I have a pretty good shop setup at home.
Beyond that... Lighting, Bilstein shocks, Tru Tracs, not sure what else at this point. I figure it'll need a new front driveshaft at some point.
I should probably do a build thread...
Like many DII owners, I went for the OME lift with HD springs and OME shocks. I'd say it gave me a modest 2" of lift. Just right. Matched with larger tires, it offers plenty of clearance for what I do. To me, it seemed silly to clad my DII in sliders, bumpers and misc armour if I was rolling into trails with the same clearance as a Dodge Caravan.
If you're going to do all that to a DII you may as well lift it at least 2 inches ... the weight of the HD bumpers alone is going to knock a one inch lift back to stock height anyway. If you're locking it chances are pretty good you'll need the ground clearance if you're going somewhere they'll be needed.
A two inch OME these days on these trucks is small and almost made specifically for the 50/50 driver. I was at MAR last year and saw that 3-inch was the new standard, so with a two inch you're not going extreme but you'll definitely notice hitting a lot less things on the trail. I've found an OME lift on some beefier tires with CDL gets me to where I want to go and then some and my truck still looks as it was intended.
Just my opinion though, and there are lots of them out there.
Here is a cheap option for on the hood. This was easy for b/c the yj has exposed hinges that I attached it to.
That was the logic that guided my decision to go with the OME 2" lift. I could have dumped $5000 in fancy mods like bumpers, winches, racks, lockers and so on, but with the factory ride height I was struggling with even mild trails.
I agree with you.
I am running a 2" RTE lift with 265/75/16's and couldn't be happier.
I've tried several mounting locations for the hi-lift. I didn't like having the hi-lift up on the roofrack at all. Extra weight, difficult to get to in many situations, snags on trees, etc.
On a moderate build-up where you are trying to keep the exterior of the vehicle very stock you can put the shorter hi-lift in the rear cargo area. I'll see if I can find a photo.
Mounting it to the bullbar works very well. Easy to access, puts weight forward on the D2 which has a light nose already, keeps the weight down, and gives your truck a "trail ready" look... The last one might be a con for some. If you want to mount one to your bullbar, I wrote up how to do it with the Coleman racing brackets (very simple).
I am storing my inside, after see what the weather can, and how fast it starts to rust. I have a 48"(cut down to 44") to fit on the rear floor behind the rear seat. It is a great place to store it.
Also, hilift jacks do work as winchs, but you only do it once and then buy a real winch. It is a lot of work and dangerous to control. Think about buying a winch for winching and use the hilift jack for jacking.
Buy it and after a couple of trips you will find the spot that works for you.
I did this on my old RRC. Made 2 brackets that bolted to the existing seat hardware. Very easy to do and very secure.
I live in Washington near the coast and have had mine on the bullbar for 3 years w/o a rust problem. I hit the ratcheting mechanism with WD40 each time I change the oil.
C
I was living in IL, where they salt the roads so heavily in the winter you can't tell if it salt or snow on the road. Now that I am in KS, there would be no real issues with it outside.
For sure I wouldn't leave it mounted exterior during the winter. The salt would just kill it. Though, where I live now, they don't actually salt that much. It's a rural area and I guess they figure more rural people have the sense to buy snow tires for the winter. ;)
I don't like the idea of it being mounted inside too much, because of the space that it takes and I really don't like the possibility of it flying around too much. It would have to be VERY stout mounting.
I was in a heavy frontal collision in a Focus once, and I was surprised how much the luggage in the trunk pushed through the rear seatback. It tweaked the seat quite a bit.
As it is, I'm planning on making some kind of rear cargo cage so I can stack things in the back without worry of them coming through the front. More than just a dog guard.
Bumper mount......doubles as a snow margarita bar.....
just grease it....
3" RTE suspension and 33's
LukeSkywalker515
