Here are some pictures of mobile antennas presently in use. As you can see I like to build the bases a little differently, and primarily for HF use. The red lumps are stand-off insulators normally used to support buss bars and heavy components inside electrical equipment. They work well at RF and internal capacitance is low, on the order of 5 to 10 pF. That's better than some professional bases. They are reasonably cheap, very robust, and mount anywhere. You can see how they are fed in the pictures, with large home made copper washers as terminals. Just bolt them to the roof rack, roll bar, fender, where ever.
I tap the insulators for 3/8" x 24 if they aren't already. If the parts don't have 3/8" x 24, I modify them. That matches many antenna mounts, and everything fits together for mix and match. The antennas are various bits and pieces from commercial antennas, CB whips, end even fer-real antennas (like the Hustler mounted on the front bumper). The tiltover is a 1" x 10 (?) Shakespeare marine base, and the adapter is made from copper plumbing pieces.
A handful of CB whips from garage sales makes good building material. The stainless ones can be trimmed for 10m, and the fiberglass rods ones can be stripped and rewound. Can even make a good 2m antenna that way.
Those buss bar insulators can be coil forms, too. Just wind a larger coil out of 1/4" copper tubing and mount it across the insulator. Insert that higher up in the mast to resonate the antenna. Various pieces of aluminum tubing with 3/8 x 24 ends make antenna extenders to 'tune' for different frequencies.
Bob
WB4ETT
