Tanner
Somewhat new to the forum, been lurking for quite some time. I have an 07 DCLB I'm going to set up for camping. I decided to get a rooftop tent, I built the rack for it this weekend, thought I would post it. Its similar to the one AllPro sells.
I used 2 1/2" x 1/4" angle for the rails, 1 5/16" for the main tubes and 1 1/8" for the top. Kind of odd sizes but it's all the machine shop I deal with had at the time.
I don't have a tube bender, so I filled the tubes with sand and capped the ends then heated them and pulled them around by hand. It took a little longer but I was happy with the results.
I bent the pipe the same angle as the back window, and kept it fairly low so the tent wouldn't be up so high when closed up. Haven't got the tent yet but i believe its 12", the rack is about 14" to the top.
I slotted the holes just to make it a little easier to get the bolts started.
Primed
Never finished painting it, but thats how it sits on the truck. I left it a bit shorter to save a little weight as Ill mostly be putting it on and off myself. Its 56" long.
Primed
