I suppose there's all sorts of reasons for wanting a sink. For me it's because I like to cook. But, I'm also lazy. Doing the dishes, and especially multiple pots and pans, afterwards isnt one of my favorite things. I wanted a sink -- or more precisely, running water -- to help make doing the dishes easy. Here's what I came up with.
It's just a restaurant bus pan for the basin, a pressure controlled pump, a faucet, and a handheld sprayer. The basin doenst have a drain and that's by design. The soapy gray water just accumulates during the dish washing phase. This, I feel, helps to conserve the limited water I carry. If an unlimited water supply was the norm, I'd probably consider adding a drain into a tank. But as it is, I just dump the gray water when the clean up is complete.
So... what's in the box?
The box serves as my kitchen utility center. It's contains a couple of 9ah security batteries, a
FloJet 2.9 GPM pump, fuse box,
switches, some power outlets,
and plumbing.
The switches control the anderson connections on the back and are great for lighting. They also control the "cigarette lighter" outlet on the top as well as USB ports (power ony).
The plumbing fits nicely inside the box for travel.
Here's a (not so good) shot of it all in action.
The pump is surprisingly good with it's power consumption. The batteries will run it for about 60 gallons of water. Considering I'll use less than 10 for a week in the woods there plenty of juice left over for lighting and playing tunes. Of course recharging from the truck or simply running the whole set up from the truck's aux battery is also an option.
Until I came up with this idea I'd been thinking that an on board water system would do what I wanted. Now, I'm not so sure. I still might get around to doing it but the need doesnt seem as urgent.
