jacobconroy
Hillbilly of Leisure
Hi All,
I just purchased a Worthington 308970 horizontal propane tank from Amazon. I intend to mount it to the side of a Teraflex Alta rack on my JK. I run a Propex heater, Partner stove, and sometimes a propane camp fire (during stage 2 fire restrictions). So, after some testing I've found that a 20 lb tank is necessary for my needs, and space is tight in the Jeep.
I'm concerned that I purchased the wrong tank. It is intended to be used for propane forklifts, and when it arrived today I see that it has a funky (though very nice) thread-on adapter included for connecting a hose. The item is said to be, "horizontal use only, vapor service only, and vertical fill".
It has a very nice gauge built in. My thought is that I will finally be able to see how much propane I have, and I will be able to easily reach the valve since it's horizontal...and high up on the rack.
Can I ask any local propane shop to fill this tank (in the vertical position), install it horizontally on my Jeep, and attach the items mentioned above? My best guess is that I can. An experienced opinion would be great. I think that "vapor service only" means that it functions like any other vertical, run-of-the-mill 20 lb propane tanks. Such as you would connect to a grill.
Thanks.
Thanks.
