ddelsobral
I'm just curious - for camper vans, how often do people need to change flat tires? And for those that have winches, how often do they get used?
34 years of 4 wheeling I think the only flat I had was from breaking a bead in the rocks when aired down too low without beadlocks. Seated bead and was on my way.
As mentioned above modern tires are pretty darned good. I believe if you have a quality off road tire and pay attention flats are rare. They are very rare on the tread portion. More common is a sidewall and that is usually from brushing up against a sharp rock.
I have gotten nails and screws in my tires around town. A plug or patch solves that problem.
Flat tires will depend on what roads you drive. If you are mostly on pavement, chances for a flat are pretty remote. On the other hand, if you travel primarily dirt roads you'd better have some tires that won't get rock breaks.
Our experience with our own vehicles is the following:And where you plan to drive is also a big decider.
Toyos are strong but my near new MT's ate it on I-5 south in San Diego. A piece of metal went in between the voids and instant destruction. I had to buy a new one. Cha ching. My Toyo AT2's picked up a pretty long screw. Same deal between the voids. This time I was able to patch it and Discount repaired it again with a new plug and a boot. Regardless,I'll get them again. Caca pasa. Stuff happens.Flat tires will depend on what roads you drive. If you are mostly on pavement, chances for a flat are pretty remote. On the other hand, if you travel primarily dirt roads you'd better have some tires that won't get rock breaks. I've found that the more plies - not ply ratings, actual plies - in the tread of the tire makes a big difference when driving dirt roads. Which is why I finally ended up with the Toyos on my van, with an actual 7 plies in the tread. Haven't had a rock break yet. Last year I had to replace the OEM tires on my F150 with Load Range E because of flats (rock breaks) in the OEM tires.
Good, wide well-maintained dirt road. But a hundred miles of this stuff is not conducive to long life of an OEM P-rated tire:
As far as a winch - I have one but never had to use it to extricate myself. But it has come in handy pulling downed trees off the roadway.
