Stumpalump
https://www.tacomaworld.com/tirecalc?tires=235-75r15-255-70r15
Using the above link enter the tire size found on your door sticker and your new tire size.
Add the width percentage increase and the side wall height percentage increase. Take that total percentage and subtract it from the pressure recomended on your door sticker. That's your new pressure.
So in my case above The stock tire was 235/75-15 and new larger tire is 255/70-15.
It's 8.5% wider and has 1.3% increase in sidewall height or 9.8% that's a 9.8% increase in air volume.
32 psi is recomended on the door panel so I multiply it by .098 and that equals 3.136.
Now I subtract the 3.136 from the original 32 and get my new pressure of 28.864 psi. lets say 29 pounds.
Does this math using percentage of volume vs pressure add up?
https://youtu.be/GBtbirNyzMA
