how to properly hook up power in pop-up camper battery
Depends on what you use it for. If all you are doing is charging the secondary battery, then 100a will be enough. If you are doing something hefty like running a winch off the secondary battery, then go for the 200a.
And what're the details on the recall?
http://www.cooperindustries.com/content/public/en/bussmann/transportation/recall_info_NA.html
We have been conducting an investigation, including extensive analysis and testing, and though we have not yet been able to determine the actual cause of the thermal events, we currently believe that some units may suffer an internal circuit board capacitor failure, which could lead to overheating, smoke and, on rare occasions, fire.
Ah. Thanks. I remember when a whole lot of computer motherboards failed due to bad capacitors made overseas.
Marflaca
