That is good information. Thank you. Are there any other issues in having this size set up I need to know about? WOuld you recomend increasing the braking system on my fj? Thank you for your insight. 3500lbs shouldnt be too hard to stay under. ( I dont have that much stuff)
You could put TRD brakes on the FJ..... I think 17" wheels are mandatory and you are limited to stock lower control arms......
Sat I hooked a friends Tear Drop up to my box stock 2011 FJ and drug it around the Northern Sacramento Valley for awhile to see how it would do.... I learned.
1. An 800lb Tear Drop will grow to approx 1200lbs with what appears to be little or no "add ons". I know, I backed it onto a scale at a another friends ranch.... Probably weighed a bit more since the tounge weight was on the FJ which was off the scale....
2. The FJ stops 1200 + lbs pretty good BUT it wouldn't take much of a grade to get the brakes hot in a hurry not to mention one OH S&%T moment and your toast....
3. Some sort of off-road hitch is mandatory. I put "witness" marks on both sides of the ball w/o even trying.....
4. The stock Dunflop AT-20's SUCK.... Oh wait, my bad, that's a good story for a tire thread.....
YMMV RON
PS I'm doing a Sierra 4X4 trailer with RTT this fall if all goes well. On paper it's gone from 640lbs to 900ish lbs w/o getting too serious.....
