TL;DR - Is there a product "off the shelf" that would provide for control of 12VDC accessories that would turn on any time it's provided with an ignition signal, AND would also turn on at a specified time? Such as any time the ignition is on, the accessories are powered. Turn off ignition, it goes into X-minutes/hours delay mode. Just like any typical delay timer. But every morning, at 4am, it turns on regardless of ignition status, and runs for the programmed delay time. Ideally, I'd like to be able to program it for say Monday through Friday, but I could deal with daily. I suspect I'm just not using correct search terms in Google for this...I have a plan in mind of how I could accomplish this with something like an Arduino and a relay, but I'm also curious if there is already a similar solution on the market.
My situation - we all carry coolers on our work trucks for bottled water, and it's great that the company provides the coolers and all the ice we can use, but after switching 100% to compressor refrigerators years ago in my personal rigs, I did the same in the work truck, though in a "unapproved modification" form, lol. For a while I was parking my work truck in the back 40 next to a light pole with a power outlet, and just plugging in every night to keep the fridge running and cold. Unfortunently, that ended several months before this COVID thing, when we had reorganization, and the dept insisted that we park all the trucks together near the building, where there isn't easily accessible AC power, . I tried to avoid it, but you know..the whole "choose your battles" thing.
So, given that I start my day at 6am, I'd like the fridge to turn on at 4am to pre-cool it before I get to the truck, along with it running all day while I'm running around handling service calls. I've tested it before, and on my little 15L fridge, two to three hours is plenty enough to get the drinks cool enough. But at the same time, I don't want to leave it running 24/7 and potentially drain batteries, especially over the weekend. I know "extra battery and solar" is the simple solution to this, but an extra battery, solar panel, and associated wiring would definitely be an "unapproved modification" to the truck which would be questioned any time it went in for service. Whereas an additional timer box and DC plug/socket wouldn't be noticed, with the fridge itself being easily removed.
