Martinjmpr
Wiffleball Batter
An old saying I heard in the Army was "If it's stupid but it works, it isn't stupid."
So I'm tapping into the collective wisdom here to see if this idea is stupid or if it will likely work.
First off, I originally posted this a couple months back as a response to this thread, because what I'm thinking of is similar:
Here's the situation: I have an Indel-B TB-41 refrigerator (Truckfridge TF-41) that we use when camping. The fridge sits in the cab of the truck (2018 F-150.)
My previous vehicle was a Chevy Suburban with a dual battery, and I ran the fridge off the "house battery" which was charged when the engine was on and isolated when it was not. Putting a 2nd battery in the engine compartment of my F-150 isn't possible so as an alternative, I made an inexpensive "power box" with a 12v, 90ah wet cell battery. The fridge stays hooked up to this.
My issue, then, is how to get power to the auxiliary battery to keep it charged up while on long trips? I actually purchased as Renogy 20a DC-DC battery charger last year with the intention of running a pair of wires from the factory battery back into the cab. My only dilemma currently is that I haven't found a good way to get the wire from under the hood into the cab. I do have a nice space under the back seat tha the DC-DC charger will fit neatly into.
HOWEVER, Something else occurred to me: Like many vehicles today, my F-150 came from the factory with a 400W inverter. The inverter goes to a 120vAC plug in the dashboard. This plug is ONLY powered when the ignition is on (that's an important part of my plan.)
So I got to thinking: Seeing as how I have 400W of usable AC power, why couldn't I just get a 120v AC battery charger and plug it into the inverter plug? The charger I'm considering is this one:
Per the specs, this is a 7.2a charger that draws 132W.
Now I know the salty electrical gurus out there are probably clutching at their pearls at the thought of such a sloppy setup. After all, it seems silly to take 12v DC power from the charging system -----> Convert that to 120v AC ---------> Convert that BACK to 12v DC to charge the battery. Seems like there is probably a lot of wasted power.
I totally get that there are much more "elegant" ways to achieve the same goal (keeping my "power box" charged up.)
I totally get that this seems sort of "jury rigged."
But my question for the group, going back to the topic sentence here, is: As 'stupid' as this might be, WOULD IT WORK? And if not, why not? What am I not considering here?
Keep in mind that the inverter only works when the ignition is on, which in practical terms means the engine is running and the alternator is charging the battery. So I don't see much of a concern that the charger will draw down the truck's battery since it won't be drawing any power when the truck is turned off. As for the power draw, the 132W draw is well under the 400W capacity of the inverter.
I'll reiterate that ultimately I want to use the 20A DC-DC charger to keep the power box charged up. And while 7.2A is not 20A, it seems to me that a 7.2a charge ought to keep the power box charged up for several days, at least, assuming that I'm driving for 3 - 4 hours a day minimum. The fridge draws an average of 2 - 4a depending on how hot it is. On an extended trip, it seems likely that th 7.2A charger might not be able to keep up with the discharge of the battery that is constantly running the fridge.
But for a short trip - 3 to 5 days, I can't think of why this WOULDN'T work.
Can I plug a trickle charger into a Toyota factory inverter.
My wife’s car a Toyota 4 runner has an inverter built into the cargo area. It says it is good for 400 watts. I have a 2 amp trickle charger I want to use to keep a spare battery topped off while driving. When I am parked the spare battery will be used for a fridge overnight. I Will plug the...
www.expeditionportal.com
