Does anyone know the back spacing and bolt pattern for an 08 JK Sahara? Thanks.
datrupr Expedition Leader Apr 22, 2009 #1 Does anyone know the back spacing and bolt pattern for an 08 JK Sahara? Thanks.
datrupr Expedition Leader Apr 22, 2009 #4 Also, on said JK Sahara. Is there an issue going from 18" wheels to say 16"? Thanks.
Root Moose Expedition Leader Apr 22, 2009 #5 IIRC brakes are all the same on all JKs (at least NA spec). Confirm that though.
D dryrock New member Apr 22, 2009 #6 Backspacing Backspacing on the factory JK wheels is 6.25" 16" wheels work fine. There are issues with most 15" wheels though.
K keithro Adventurer Apr 22, 2009 #7 All of the brakes are the same. All of the tires/wheel combos are interchangeable (sahara/rubicon/x) There are a lot of people running 15's, but I'd check clearance with the exact wheel before buying anything....I'd go minimum 16's
booger Observer Apr 23, 2009 #8 you'll have to do a little grinding on the brake calipers to run 15s, but it is possible.
