Jeep reveals Moab Easter Jeep Safari concepts
Frank
http://www.autoblog.com/2013/03/20/jeep-2013-moab-easter-jeep-safari-concepts/
Jeep has unveiled its annual spate of concepts before the Easter Jeep Safari. Those start with the Grand Cherokee Trailhawk Concept (below left), complete with the company's EcoDiesel V6 engine. Designers threw in a set of 35-inch Mickey Thompson tires wrapped around 17-inch Rubicon wheels, and a set of custom fender flares help keep all that rubber under wraps.
Meanwhile, the Wrangler Mopar Recon (below right) packs a 6.4-liter Hemi V8 good for 470 horsepower. All that grunt gets to the ground via a five-speed automatic transmission and a set of a Dana 60 axles frond and rear with 4.10 gears. The Recon also makes use of a 4.5-inch prototype long-arm kit and a set of prototype eight-lug bead lock wheels.
The Wrangler Stitch (below left) builds on the momentum of the Wrangler Pork Chop Concept. Engineers once again set out to strike as much weight as possible from the vehicle, and actually managed to trim the curb weight down to 3,000 pounds. That effort has given the machine the same power to weight ratio as the Grand Cherokee SRT. Plenty of carbon fiber, door deletes and a chrome moly roll cage all help trim those pounds, and a set of DanyTrac Pro Rock 44 axles with 4.88 gears and ARB lockers front and rear let this machine scramble over whatever is in its path.
The Wrangler Sand Trooper II (very top) gets its grunt from a 5.7-liter Hemi and puts all 400 pound-feet of torque to the ground via a set of eight-lug portal axles. That hardware allows the Sand Trooper II to run 40-inch tires.
Jeep took a different approach with the Wrangler Flattop (above middle), however. With an upscale appearance, the Flattop boasts a chopped windowless hard top that shortens the machine in height by a full two inches. Designers also cut out the B pillar for a massive side opening. Katzkin leather seating indoors helps offer up a bit more refinement, and the Warn Zeon winch and 37-inch Mickey Thompson tires give the rig some added capability off road.
Finally, the Wrangler Slim (above right) is likely the most accessible of the whole bunch, showing off exactly what can be built out of a Wrangler with a little patience on a budget. The Slim features a 3.6-liter V6, axles with a 3.73 ratio, 17-inch prototype wheels and a 10th-Anniversary Rubicon front bumper. Rock rails and a two-inch lift help get the Slim off the ground.
I like
AFSOC
Before EJS I hope Jeep can get a handle on how to mount directional tread tires on the Sand Trooper II.
Is it just me or do the 2013 Rubi wheels look better on the GC than on the Wrangler? I really like the Trailhawk!
I have a '13 rubicon.... Still not sure about the wheels.
I'm interested in this slim concept. What does the name signify? It's not any more narrow than a standard JK is it? Like the YJ/TJ width?
voodoojk
its amazing that from the dozen different post in the last couple hours all over facebook and forums ect.. ect.. all anyone talks about is the tires in the sand trooper lol
m(a)ce
I'm digging the Flattop and the Trailhawk.
The 35s actually look proportional on the Trailhawk.
MattScott
Approved Vendor
Hey guys,
We'll be in Moab test driving and getting a closer look with these Jeeps next week. Be sure to check the front page for updates.
FYI, as a writer, I would get a little bit touchy if someone copy and pasted my story to another website...
Clutch
<---Pass
Ah Ya Kermit, Pimpin' righteously, Jeep can you dig it!!!
:D
Pimpin' ain't easy!
Oh, kinda disappointed with the concept vehicles, seems like they are just rehashing old concepts. Maybe I was hoping for a extra cab/4 door J12, or van bodied forward control.
Frank
FYI, as a semi-pro photographer, I don't mind if people use my work as long as a link to the original is given with the photo. I believe that is considered standard courtesy.
SANelson
