mmaattppoo
After purchasing an ARB fridge/freezer I was looking for a neat, tidy, and secure means of carrying an auxiliary AGM style deep cycle battery in the rear cargo area of my 2010 JKU.
A search through the Expo and other forums, and an extensive search on the net, yielded a few interesting options but nothing peaked my interest.
After much time designing my shelf solution in Sketchup I came up with the following:
All parts that comprise this construct are made from 1/4" aluminum angle, plate, and flat stock cut to length and fastened with 10-32 stainless steel flat head machine screws counter sunk into tapped holes for flush mounting. The whole assembly is bolted to a piece of angle that is fixed to the tub using the hard top mounting holes and 2" x 5/16" bolts/washers.
3M very high bond (VHB) tape is used to adhere the shelf where the supporting foot and rear portion of the shelf come into contact with the wheel well. The combination of bolting and taping results in a very sturdy shelf able to support the +50 lb battery I'll be mounting.
If you don't have experience with VHB tape you'll be amazed at how effective it is at bonding smooth painted and metallic surfaces...after degreasing the surface and removing any dust/lint. The use of this tape saves drilling holes and running bolts or rivets through the wheel wheel...a possible source of water leaks and corrosion.
See below for a couple of pictures of the nearly finished product:
I'll be adding a tie-down to secure the battery to the shelf so it isn't free to move in the event of an accident or while off highway.
Additionally, I'll be connecting this battery to the starting battery with a CTEK 12V DC/DC charger.
More photos to follow once I have everything secured and wired in.
