Land Rover Discovery II Parts
Brian McVickers
Administrator
Staff member
Bits and pieces from a Discovery II!
WABCO ABS Control Module / Pump $75
Thermostat $10
Extended Brake Lines $50
Pulleys $15 for both, both are used but were replaced in search of a problem and problem was not pulleys
Serpentine Belt, One is new and never used, one is used and good as spare $30 for both
CD Player $25
No guarantees, all parts were working when removed.....
Buyer pays for shipping from 86301
Thanks
Brian
Some more parts!
Radio Shack CB $25
4 flat to 7 round $10
White touch up paint $15
Random plastics $25 for the lot
Horns $20 for the set
Vents $25 for all four pieces
And a few more!
Oil Reservoir cap, small crack just under lock catch still functions fine, $10
Transfer case shifter solenoid, small break in positive wire coating, $10
Windshield water bottle down tube, free if you get something else!
Spare tire Hi-Lift and Shovel + Lock system $25
Front Swaybar links $10
Yakima Bike front fork holder $10
Air Bags $100 for the set of 4
Dashboard plate $20
Front passenger airbag $50
And...
A bag of wire looms including the AMFM receiver $20
Airbag control Unit $20
Window regulator $20
Body Control Unit $20
Cruise control unit $20
This thing $10
These connectors $10 for the lot of them
Rear swaybar connections $20
Door window switches $20
Seat belts $25 for the lot
Big wiring loom $35
Door seals $20
Window switches $20 for the set
Magnetic oil plug and OEM plastic diff plugs $15 for set
Sunroof switches $10
Switch Cluster $50
Sunroof control unit $15
Mirror switch $10
Cruise switch $10
Bag of bolts, $5
Bump!!!
Lots of random parts here.
If you want a few of them let's talk package deal!
Want to make an offer on something, I'm all ears.
Hi Brian, new member here just picked up a 01 disco 2 last week and am interested in some of your parts, can you let me know what you still have? I could pick up, as I'm in Arizona as well. Thanks in advance.
jgwarren319
