lc200 suspension
aaronteh
I am looking for a lc200 but I can't differentiate between the air suspension and the notmal coil suspension and wondering which is better
I think it depends on your plans regarding modifications. If you are planning to add a lift then the standard suspension would make the most sense. If you are going to keep the rig stock then the AHC suspension will give some added ground clearance when you need it along with load leveling. Of course the AHC adds complexity which could affect long term reliability.
different model
At Malaysia there are no brand new land cruiser only used from uk ,china ...... so there also got a lot of different engines and suspension depends on which country .
Dynamo TCX
