Lets see some full size pictures...
From this past weekend... We spent a good 4 hours screwing around in the forest above Pinecrest, CA. The Sierra is my partners and 2wd with the factory locker, a little bit of lift and some 33" tires and it got up/over/around a LOT of stuff I was not expecting it to.
Up next for it is a bit more lift and coilovers in the front, LT shackles in the rear and ditching the overload leaf and adding some smaller leafs to build a more progressive spring pack as well as looking into a better front bumper soloution because it, uh, scrapped a lot.
523968
Picked up the bed rack I had buddy build for the Autohome Columbus. I'm pretty stoked with the outcome overall. I just have to get rid of the white with some vinyl down the road. Nice cruiser/casual camper 4x4 rig that still gets 23-25mpg on the highway. You can't see it but I have a decked storage system in the bed.
Is that a lowered 4x4? What engine?
The Deaver mini-pack is expensive but 110% worth it. I put new OEM leafs and the Deaver mini pack on my '05 and it made an unbelievable difference. The long travel shackles will lower the truck, and not necessary unless you get longer leafs. My truck will flex to the bump stops hit and shocks max out with the stock size shackles.
It's running a belltech 3/6 drop (originally had a 4/6). Z71 4X4 with the 5.3L V8. I find 90% of the time I'm camping with friends or with a group and they end up in a spot where a stock truck can drive. Might as well make a simple trip more challenging ?
I had a lowered mini truck for a long time. I would get phone calls from my friends who had lifted trucks who wanted to borrow mine to move stuff. It’s a lot easier to load a lawn tractor into a truck when it’s two feet closer to the ground. Four wheelers didn’t even need ramps, just drive right in!
Yeah, that gets old.
12' ramps are available online. I saved the link to my phone, to email to mooches.
https://www.discountramps.com/folding-quad-ramps/p/MF2-14438/
It's not a truck if it don't have ramps.
The Deaver mini-pack is an option still so its good to hear that they're working out that well. What length shocks are you running on your truck and did you run into any issues with the brake lines or parking break cables?
Our truck currently has an add-a-leaf in the back, so the back is sitting up a bunch and a small drop in the rear wouldn't be a bad thing imo. The dirtking LT shackles angle forward and are an inch longer and are designed for stock length leafs, so its an option we're still sort of keeping on the table after we put longer shocks and longer lines as the brake hose is almost taught when the shocks are topped out.
Right now it'll flex from the bumps to the end of shocks. Given that ours is 2WD, getting as much flex as possible is going to be pretty key for the maximizing the somewhat limited off-road abilities of this truck.
I'm running factory replacement Bilstein 4600s. I could gain a couple inches of droop by going longer, but I don't really need it and these shocks still have life left in them. Plenty of room left in the brake hoses and parking brake cables. Its probably 1-2" over the stock Z71 height right now... 24.5" from center of the wheel to bottom of the fender.
  • Like
Reactions: rho
Ah, ok. cool. Ours is a little bit taller than that, so that might be why. I'll get some measurements in the next few days.... Gotta say that in general I'm impressed with how well the rear leafs ride and articulate on these trucks.
2eleven
