Lets see the Expo Cruisers!
CodyLX450 said:
Finally got my monster step sliders...no more people falling out of the truck...:P
That's hot dude. What size rubber?
Baja Bound Mule work in process
Current Stuff,
OEM Rear Ladder, Conferr Roof Rack 4’x7’, with mounted shovel,3” OME Suspension Lift 850J/863 L shocks (J springs front, HD rears),295/75/16 Nitto Terra Grapplers ATs, OME Castor Correction Bushings, Hand Held Uniden CB Radio wit Lil Wilson Mag Mount Antenna, 12v air compressor, Power Points-2 front center console, 2 rear cab, Dome and Courtesy LEDs, Slee Transfer Skid Plate, PHH Silicone Kit, Low Cost Storage, Frame to Axle SS brake lines, (2) Scepter 5 gallon gas cans, (2) Scepter 5 gallon water cans, Raised Differential breather hoses, Hi-Lift Jack w Hi-Lift mate, Recovery Gear, Fire Extinguisher, 2 Work Utility Lights in Rear, 4xinnovations sliders bolt on, 2 Fuse Blocks (1 in cab, 1 in engine bay), Front Tinted Windows, Garmin eTrex Vista GPS, Yakima Bike Rack, Small Power inverter
latinoguy said:
Current Stuff,
What size mounts do you have for the rack?
latinoguy said:
Current Stuff,
Is that pic in Sedona?
Are you referring to the rack mounts? I bought the rack used, and I believe the rack mounts are the standard mounts (I think some refer them as bulldog mounts) The shovel is mounted with quickfists...the same goes for the ax which is mounted to the storage unit..
Yep, that is Broken Arrow where the pic was taken..fun trail...
Here is mine and my first post
1970 fj55 (with a 73 almost perfict shell for future body swap)
4bt cummins, nv4500, 3spd t-case. (split case going in at body swap)
ARBs front and rear, Via air compressor
35" mts going to ATs
SOA. rear springs 11 leaf custom set from National spring in El Cajon CA. fronts are stock with full legnth add a leaf. I have had this spring set-up for over 15 years and love it. 11 leafs in the rear because I have one of the old Man-A-Fre 53gal fuel tanks., SR, shower, custom interior. custom bumpers F&R
Soon too Be done
60 series axels. Stock 55 axels and 4bt and SOA do not work! you will hit the oil pan and put a hole in it. ask me how I know.
Body swap
35"ATs
ham raido
and on and on.........................
Soon too Be done
Body swap
35"ATs
ham raido
Sweet another Piggy!!!
Where are you located?
1988 HJ61 "Marmaduke"
12H-T, Intercooler , 3" staight pipe exhuast, manual boost control, Isspro oil/boost/pyro gauges, A440, extreme valve body, tranny cooler, powershot 2000 propane inj, factory cable lockers, factory PTO winch, SOA on Dakkars with c&t, 2" body lift, poly body mounts, rear FF, traction bar, ARP knuckle and hub studs, 30 spline Longfields, 5.29s, 38x14.5R16 Toyo MTs, Lukes 4x4 high steer, Sky front widening kit, rear 1.5" spacer, home brew hydro assist, H.A.D. Custom driveshafts, 24V-12V Solar converter, 7 amp charge regulator, Optima blue top third battery, +12V fuse block, 1000W inverter, 80 series MC, V6 calipers, SS brake lines, Cobra CB radio, Alpine deck, Safari Snorkel, custom bumpers/sliders, Yakima racks, Cibie/bosch e-code 100W high/low headlights with upgrade wiring harness, Custom low budget drawers and bed system, Magellin GPS, compass, rear swing out tire/high lift/shovel carrier and swing out fuel carrier, on board shower, ARB fridge placement, under body storage, OBA, HAM radio. M101 Military trailer with cut out tail gate SOA on 9.00R16 XLs on split rims.
Full recovery gear/first aid.
On the wish list:, Long range fuel tank, RTT for the trailer, onboard water storage for the trailer, custom propane bottle with remote fill for injection system/camping.
HButton
