The lift was there when I bought the LJ July 2017, but I believe it is around a 3", I added the wide flares to clear rubbing when flexed while turning, and I added Nth's rear spring relocators, which raised the backend a bit, made a nicer stance actually. Yes I have the Nth belly pan and oil pan skid and rear stinger torque bar with diff slider. Always liked their products (except their sway bar links). If you can get any of their products I think they will serve you well. Know-Where - 2 - Jeep used to handle the 'long defunct' Nth product line but I heard rumors of KW2J not being around any longer. I know I tried for a long time to get the Slider for the front Dana 44 but no luck, they have stopped communicating. Glad I had the bellyup and oil pan and rear Slider tho, each had new scraps on them after the Rubicon run. In fact I checked underneath the other day and the rear Slider saved a huge impact on the u-joint connection in the rear driveline at the diff connection! As far as the long arm concept, I have never been a fan, but then again I've never ridden in a Jeep with a long arm. I see too many videos where the long arm is dragging over the rock ledges. I do think the Nth design addresses the clearance issue tho with a bent design.. I am sure there are many on the board (or other boards) that have more knowledgeable input on the matter. Only resource I know of now is American Expedition Vehicle's used parts forum. Good luck!With the old tires.
Sorry, I responded to your question but with someone else's quote - dang technology!Bluejeep, what suspension are you running with "35" Coopers, Nth degree diff skids and tummy tuck"? I've used the Nth degree tummy tuck before and really like it. I'm about to put a RE 5inch long arm under my LJ, but see Nth degree has a long arm as well. Any thoughts?
Here's my 2006 LJ Rubicon, currently has 71k on the clock with 35s and a bunch of other mods that I added. Went to Missouri this year for an overlanding trip! Might sell her soon though :sadface:
Waiting on my XJ to come back from the shop.LJRubiReal, are you going to post it for sale on the forum?
