Quoted for fact.
Some of the most expensive have the most ridiculous claims.
Like having a blue lens and claiming that you can see better with it. In any condition. Laughable.
How can a filter make a light brighter? How can you filter out ROY (red/orange/yellow), keep the blue, and not have more glare?
Just to add to this...
What I find even more puzzling is the LED light fad currently raging out there (both for offroad vehicle lights and flashlights). Without any filters or anything these lights put out super-massive amounts of very narrowbanded blue light energy along with a minimal amount of energy in the red/orange/yellow region just to make the beam itself appear "white", which results in far more glare (to me, anyway) than if one were to just put the blue filter you mention over an incandescent or other type light. More interesting is how few-to-none of the LED light manufacturers seem to understand this limitation of phosphor-based LEDs (the kind virtually all LED lighting products use), and how that impacts the light's spectral output when they select the exceedingly high color temperature LED chips that they do.
I briefly dabbled in the LED flashlight craze for a moment myself, but then returned to my trusty little old 2 D-cell MagLite which I converted to run off AA-NiMH rechargeables with a 6-cell incandescent (Xenon) bulb about 12 years ago.
FWIW, I have a pair of Pilot 55W slim lights (2" x 5.5" thereabouts) mounted in my rear bumper as backup lights. They're pretty bright, though I haven't really compared them to see how well their beam definition is (stray light being cast upward, etc.). They don't have glare shields over the bulbs so I wouldn't think they'd do well in fog, but might be OK as a driving light used in conjunction with your high beams?
Also, something to be aware of... Putting 100W bulbs into too small of a housing can cause the bulbs to overheat and burn out (I know, I've tried this before myself). It seems the cutoff point is about a 6" round housing, or a 5x7" rectangle housing for a 100W bulb (and even then, if the housing's internal reflector isn't vented like my ProComp 100s weren't, the bulbs can still run too hot if you have good strong wiring running to them). You'll know this to be the case if the bulbs last for a few on-cycles and then turn all black & blue before quitting altogether.
