dieck
kcowyo said:I have a 2nd gen TRD supercharger on my '97 T100, with a tranny cooler too. No real complaints but I don't seem to have the initial throttle response like a couple of d'cab tacos with the SC that I've driven. Once it starts getting above 2800rpms, it does great, smooth through the whole power band. It just doesn't have that initial "snap", when you punch it like in the Tacomas.
Some of that I attribute to the T being heavier, by about 600lbs. It could be the gears, but I have stock 4.30's and I thought the d'cab tacomas did too? Also the Tacomas were new (less than 2K miles) at the time and the SC was installed when new. I have close to 50K on my SC now and some say the nose needs to be rebuilt around 60K.
On Yotatech.com, there is a member, Midiwall, who has done a ton of research and testing with Gadget on his SC. Some good reading and facts if you're still collecting info on fuel and tranny mods. It seems that there are varied performance results based on altitude as well, with regards to pinging and lean out. Owners in higher elevation areas like CO, report fewer problems than those closer to sea level. There are many variables, opinions and mixed results with the SC, but I've been very happy with mine.
Wow. Great info. Mine seems to have the accelleration snap and I'm still on stock 4.10 gears. What is your daily driving weight do you know? I'm still on my second tank of gas so I wouldn't call any of my conclusions mature yet regarding ping or running lean. I tool along most of the time under 2Krpm and love the low end torque with the charger.
Does the T100 have the 3.4 or the 3.0 liter engine? If you have the 3.0 that could explain some of the difference.
I'm very pleased with the charger and the taco as well. I wish the 05's retained more of the rugged simplicity of the 01-04's The new engine is no slouch though.
