Like New 2011 Coleman E3 Evolution Pop Up Camper Off Road Edition - ATV Hauler
strgcheez
https://www.flickr.com/photos/36013288@N02/albums/72157635086519850
Price: $10,900
Contact: Andy (901) 337-7878
History:
This trailer has been garage kept most of its life and used less than 15 times! It is fully loaded and in excellent condition!
Description:
The trailer is pet, smoke, and leak free. It has the added roof AC, awning, slide-out dinette, two king beds slide out, 4'6" x 7' front deck with integrated ramps (800lb. capacity for ATV, scooters, small motorcycle), swing-level galley (not flip-over galley), heat, 3 way fridge, water heater, inside stove top, dual propane tanks, deep bowl porcelain sink, large water tank (35 gallon), bay window, shower, cassette toilet, alloy spare tire, stereo, outdoor speakers, outside shower, and outdoor cook stove.
Additonal Info
The E3 will be fully detailed/sanitized inside and out before pickup. It will be waxed and sealed. Every crack and crevice will be covered! I have all the original owners manuals/ service records and everything you need to go camping. This camper is ready to hit the road!
Specifications:
* Hitch Weight: 420 lbs
* Dry Weight: 3,030 lbs
* Gross Weight: 4,400 lbs
* Maximum Carrying Capacity: 1,370 lbs
* Gear Deck Carrying Capacity: 800 lbs
* Box Size (Inside Length): 12'
* Gear Deck Dimensions (L x W): 4'6" x 7'0"
* Dimensions Open (L x W): 27' 1" x 11' 4"
* Dimensions Closed (L x W): 21' 9" x 7' 5"
* Height: 8'11"
* Interior Height: 6'8"
* Fresh Water Capacity: 35 gals
* Furnace BTU: 16,000
* Sleeps: 6
* Tire Size: LT235/75R15
* Slides: 1
* Heavy Duty 6" Tubular Frame
* Front Cargo Deck Exterior
* Bed Step
* Booth Dinette w/Portable Table
* Slide Out
* 2 Burner Range
* Single Galley Sink
* Cassette Potti w/Shower
* 6" Powder Coated Rear Bumper
* Steel Rimmed Recessed Rear Lights
* Shock Absorbers
* Steel Wheel Wells
* Molded Impact Resistant Wheel Well Extensions
* Diamond Embossed Body Panels
* Mud Flaps
* 15" Off Road Raised White Letter Tires On Alloy Rims
* Double Entry Step
* Exterior Wash Down Station
* Backsaver Bed Sopport Legs
* 5.3 Gallon Black Water Holding Tank
* 6 Gallon Hot Water Heater
* 1.9 cu. ft. Three-Way Refrigerator
* Two Burner Stove
* 5 Gallon Above Floor Fresh Water Holding Tank
* 2 lp tanks (gal/lbs) 9.4/40
FiscAnd
