Little Guy
I sent him a link to the thread; he'll read it when he gets home.
Chemo was like Club Med compared to radiation, btw. I could handle chemo again; if I had to face radiation for another series... ...not sure what I'd do really.
I have a PET scan one week from today to find out.
No way to direct the grey water away from the nest. Hmmm. So if I do the dishes, I spill the grey water under my sleeping quarters.
Anybody see a potential problem with that? Like attracting critters (bears, raccoons, etc) and not treading lightly and all that?
Keep in mind its also illegal to dump grey water in some places. On my build I plan to have a grey water tank but also a bypass to ground under my truck. The bypass will be for places where it is legal and I'm not really worried about critters. In most places it shouldn't be much of an issue since the dish water really shouldn't have much particulate making it though the strainer.
I agree, I would go through a year of chemo to avoid 1 day of radiation. I hope everything works out for you and your wife medical wise and trailer wise. Good luck with everything. Camping was the only thing that made me feel better after my treatments.
And as far as the brakes go, when I picked mine up at little guy I should have dialed in my brakes with the brake controller there. When I got home I tried setting my trailer brakes with my brake controller only to find the brakes weren't working. Well after some phone calls to Little Guy and some prodding around I am PRETTY sure that the brakes just need adjusting. Is that common to buy a trailer with brakes and have to crawl under to manually adjust them before setting them with brake controller? All this is new to me.
What do you mean by... "not working". Not working at all?
When I built my trailer, and finally hooked up the brakes, I found they didn't do much. I had the gain on the brake controller maxed out, and the brakes didn't do very much. Just barely could tell they were on. But, after a few thousand miles, they are now quite strong. I can lock them up with a 6 out of 10 on the gain, and the trailer can stop the whole truck on the over-ride if I want to. Not a screeching stop (well, the trailer does...) but you can tell the brakes are pretty strong. Using the truck and trailer brakes together as normal, the truck stops as fast as it can without the trailer. Maybe even faster it seems.
So, there's probably a certain amount of break-in required on new brakes.
Weight: The anticipated weight of my teardrop is ~2500lbs. Then add about 500lbs for water, gear, etc. That means a tongue weight of ~350lbs. There is no way around tongue weight. If you don't have enough you have stability problems, too much and its tough on the Jeep. I'm having a receiver tongue built in for some adjustability
Holy Moly! How come so much? That's heavier than my big steel thing.
I put most of the gear in it last night for our camping trip this weekend. Found that the cheap-o composite tool box on the tongue had warped when it was left open and didn't want to close; you have to pull on the box part of the hasp and spread the front out as you push the top down. Low quality nasty small box that wasn't worth $120 and needs replacing...
Interesting, I almost bought one of those, but it didn't fit on my tongue properly. Good thing I guess.
I got the Tekonsha Prodigy P2 because it offer a three axis pendulum.
Yes, I suggest getting the best one you can for off-road duty. Cheapo trailer brake controllers aren't really designed for 20% grades, etc.
So I dumped a cup of water down the drain. Swoosh, down the drain it went, gurgle gurgle twank twank ---- it spilled down the skidplate and found it's exit by the left wheel at the axle opening.
That's sort of how mine is set up, but I do have the pipe sticking right out of the floor so I can see it. RV shops have these little light blue coloured grey water totes on wheels. I was thinking about those. Or a hose to guide it away. It hasn't been a huge issue yet though. Plus, I'm in a RTT 6 feet on top of the whole mess so I'm less concerned.
The Jeep did not like towing this thing at all. Even using a Superchips Flashpaq set on "Towing" and with 93 octane fuel, it was pinging and could barely reach 45 mph going uphill.
Wow, that really surprises me. Like... you CAN'T go past 45, or you're trying to go easy on it? That motor has roughly the same power rating of mine, and I don't have a problem that bad. Uses a lot of gas but... Auto or manual?
How much did the old Conqueror weigh? I'd have thought it was heavier than the teardrop.
Michael,
Just for that, I'm going to tie a pork-chop under your RTT. :sombrero:
Fair enough :) Hate to see the problems you are having. It seams that some very good intentions were executed just too hastily and therfore sloppy.
And, I might as well air it now, Mirtes has a couple of tumors in her neck and they have to be treated pronto.
Tell me it's not true. You guys are really not getting spared right now. Hope all turns out well.
Bill,
I was hoping to be reading about a great weekend with the trailer meeting all of your needs. I hope they are a good company and will make every effort to fix everything to your satisfaction without a lot of hassle.
Give Mirtes my best. I hope everything works out for her with as little treatment as possible. I also hope your scan comes back clean.
Both of you, hang in there. A lot of people are thinking of and praying for you.
"Both of you, hang in there. A lot of people are thinking of and praying for you."
This....▲ ▲ ▲ ▲ ▲
The trailer **** will work itself out either way...
Good Luck
Hilldweller,
I am very, very sorry to hear about you all's health issues. I hope everything works out as best as it conceivably can. You and the missus are in my prayers.
While the health issues far, far outshadow the trailer issues, I also hope that Little Guys Trailers makes it right for you all.
JPK
A combo of no torque, the autotrans, and the weight. It almost reached 45mph. Maxed.
It was a good hill though.
This why AEV makes money with Hemi conversions and owners are begging for diesels.
Remember that it's a lifted JK automatic with 4.56 gears on 33s. Slick as a brick. Rear wheel HP is likely down around 130 and is trying to get to the road through that miserable transmission.
It's only "good" offroad.
I haven't weighed this thing but I'm guessing that it's at least 500 pounds heavier than the Conqueror but more aerodynamic. The fuel economy for this little trip was about the same as usual.
To be honest, I'm so sick of the underpowered Jeep that I talked with Ed Voyles yesterday about the Power Wagon that's been sitting there forever. It's a black 2011 and has everything but a moonroof; I fit in it great, it has 4.56s, locked at both ends, electronic swaybar discos, Hemi, 4 doors, 33s, winch.
Mirtes doesn't want me to do it until after her operation(s).
But it's singing to me. Whispering sweet nothings.
Maybe AEV will have a Hemi sweepstakes and I'll win.
I wouldnt hold it against you if you got one... they are pretty sweet. I like your Jeep, but do what makes the most sense.
I had 7 tumors removed from my thyroid, and subsequently my entire thyroid in the process. Got a cool scar from it, and medication for the rest of my life, but it wasnt too bad overall. I really hope things go well for Mirtes, keep us posted. Let her know Meghan and I are thinking of her.
Let me know if you need some help with the trailer!
~ Stump
Bill,
You and Mirtes hang in there! Fight it. We have you in our thoughts and prayers.
What do you know about the new 2012 JK with the new enigne? Wouldn't a four door have more towing capacity? You could take your JK back to stock and tranfer all the goodies over to the new one.
I'm still without my Disco. The TDi is being pulled out again.:eek:
Hey, Chris; good to hear from you and sorry about the Disco. Must be driving you a little nuts by now.
The new Pentastar will have more power and torque, pull better, have a better trans.
Not sure all the mods would swap all that well; by the time everyting was replaced, a JKU would cost more than the Power Wagon to be equipped the same. But it still wouldn't have a Hemi.
Power Wagons are a relative bargain right now.
I almost pulled the trigger on a powerwagon about 6 months ago after I had to take my Jeep to the dealer for the 10th time. Jamie begged me not to, she likes to go topless in the summer:smiley_drive: Now, Im back at the dealer for another week for my second rear main leak, I am tempted to get rid of it. Its hard because I have put in so much work, but I am constantly pissed because it is allways going in for warranty work. The powerwagon is a sweet vehicle, 41 grand at Voyles is a damn good price. Check out the powerwagon videos in Moab, pretty insane.
I talked to a Chrysler Engineer when I was at the Chrysler headquarters a couple weeks ago. He is not working in the Jeep division, but he heard from some colleges at Jeep that it is not fully certain yet if the 2012 JK already will have the pentastar engine or if the minivan engine will live on for a couple more months.
I'm a kinda on the edge as my lease runs out in August, not really sure yet what I will do.
Camp Tonneau Tents
